Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > ZL1 Engine, Exhaust, and Bolt-Ons
Old 01-10-2018, 09:39 AM   #1
Juiced1
Drives: 2012 2SS CAMARO 45th
Nick williams 102mm throttle body on sale and in stock at juiced!!!
Nick Williams Performance drive-by-wire throttle bodies are CNC precision-machined from billet aluminum to meet the demands for increased airflow on the drive-by-wire LSX performance engines. The 102mm throttle bodies require an aftermarket intake to fit the larger diameter throttle blade. They use a 6-pin late model connector that works with late model wiring harnesses. Tuning is required for installation; and the Nick Williams Performance drive-by-wire throttle bodies come complete with stepper motor and electronics installed—no need to disassemble your factory throttle body.
102MM DRIVE-BY-WIRE LS THROTTLE BODY
102MM DRIVE-BY-WIRE BOOSTED LS THROTTLE BODY (FOR CARS MAKING SERIOUS BOOST)
Juiced1 is offline   Reply With Quote
Old 01-11-2018, 03:12 PM   #2
Hellfighter
Hellfighter's Avatar
Drives: 2013 Black ZL1
Does CAI intake fit this?
Hellfighter is offline   Reply With Quote
Old 01-24-2018, 02:18 PM   #3
Juiced1
If you plan on making over 15psi we highly recommend the 102MM for boosted applications.
Yes, you just need to stretch the boot a little bit but most intake kits should work fine
Old 02-06-2018, 10:40 AM   #4
Juiced1
These systems are a must for roots style blowers. The more air you can get to your blower means the more air you can boost. Pm or call for ported blower package deals
Old 02-19-2018, 05:24 PM   #5
Juiced1
Nick Williams 102 for boosted applications
Old 03-05-2018, 03:18 PM   #6
Juiced1
A roots style blower can only boost as much air that you can push into. With a opening approximately 15% larger you can make a greater amount of power.
Old 03-18-2018, 07:52 PM   #7
Juiced1
Great power gains
Old 04-03-2018, 05:25 PM   #8
Juiced1
Call or PM for ported blower/102 upgrade
Old 04-16-2018, 09:42 PM   #9
Juiced1
Take full advantage of that blower.
Old 05-01-2018, 08:39 PM   #10
Juiced1
Order online or give us a call for pick up or installation and tuning
Old 05-13-2018, 02:17 PM   #11
Juiced1
These add big power on boosted cars. In stock and priced right
Need a tune? PM or call for an appointment
Old 05-29-2018, 08:34 PM   #12
Juiced1
Old 06-12-2018, 09:16 PM   #13
Juiced1
NW 102MM in stock
Old 06-29-2018, 03:07 PM   #14
Juiced1
In stock
102mm throttle body, nick williams
