Old 09-02-2017, 09:17 AM   #15
Chevy71
Chevy71's Avatar
Drives: 2016 2SS
Originally Posted by 96MrBass View Post
Mount it inside the air vent it will take away the in your face affect but still be bright enough. Installed a blue led raptor on my 5gen it works great.
I have my AFR in th air vent. I'll probably mount it on my gauge though. I went with yellow I believe lol
2016 2SS/Hyper Blue/M6/NPP/Navi
Forged pistons
Custom cut Brian Tooley Cam
SW long tube headers
3" stainless mid pipe - Secondary Cat delete - High flow cats
Port and polished heads-Double valve springs-platinum lifters & push rods
Cam phaser limiter - DOD delete
P1SC-1 Pro Charger 3.7 pulley
Stage II intercooler
667rwhp 577ft lbs
Chevy71 is offline   Reply With Quote
Old 09-02-2017, 09:21 AM   #16
Chevy71
Chevy71's Avatar
Drives: 2016 2SS
Originally Posted by Fraxum View Post
What is a GMR pick up?
It reads current from a wire without cutting or splicing the wire so you can get an rpm signal for a tach or shift light. This way you do not butcher your stock harness all up trying to wire one in. They work awesome!
https://www.summitracing.com/parts/m...MobileSwitchNo
Forged pistons
667rwhp 577ft lbs
Old 09-02-2017, 11:39 AM   #17
Fraxum
Fraxum's Avatar
Yes, I had one of these for my 5th gens. This works on the LT1? It's working fro you? I couldn't get a pulse test light out of the coil wire. If it does work I will ditch the ODB2 setup. It's a bit of a PIA when logging.
Old 09-02-2017, 08:15 PM   #18
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
My ngauge came with one. Pretty cool
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 09-03-2017, 12:18 PM   #19
Fraxum
Fraxum's Avatar
So the pickup worked for you?
Old 09-05-2017, 05:45 PM   #20
Chevy71
Chevy71's Avatar
Drives: 2016 2SS
I haven't installed mine yet, have been involved in other stuff with the car. We just got back from our house in Dayonta so I haven't touched it in a few days. The GMR is only picking up signal coming across your coil wire, should be purple. I see no reason why it wouldn't work, but I could b wrong. I haven't actually done it yet.
Forged pistons
667rwhp 577ft lbs
Old 09-05-2017, 05:48 PM   #21
Chevy71
Chevy71's Avatar
Drives: 2016 2SS
It doesn't stick out enough for me on my nGauge. Isn't bright enough and doesn't signal enough to me lol. It is neat, but just isn't useful for me on mine. This light has a few big leds that really stand out and it's bright so it catches my attention when I'm focusing straight ahead.
Forged pistons
667rwhp 577ft lbs
Old 09-05-2017, 05:54 PM   #22
KyWildcats
Z Bowman
KyWildcats's Avatar
Drives: 2010 2SS (SOLD), 2016 2SS, 2007 Z71
I have 3 things pluged up to my obd2 at all times. Shift light aem wideband and HP tuners no issues bought a splitter off amazon.
2016 2SS M6 Bo White Ported MSD, Bo White Ported TB, Flex Fuel Kit, Drag Pack, Rotofab, Ryan Stevens GPI tune, 15” conversion
Fastest Bolt On N/A M6 Record Holder 11.268 @ 120.268
2010 2SS/RS A6 (sold)Mods: Borla Atak Catback, Stainless Power 1 7/8 Headers, TSP VVT-3 Cam, 3200 Yank Stall, CAI Inake, Ported TB, 18" MT ET STREETS
KyWildcats is offline   Reply With Quote
Old 09-06-2017, 06:16 AM   #23
Fraxum
Fraxum's Avatar
An OBD2 splitter? I did not know there was such a thing. But if the GMR thing works then I will buy the shift gauge I should have bought and the pickup. Then will I redo the spaghetti mess under the dash for the fourth time.
I even asked Autometer if the pickup works on our cars. But no reply.
Wow here it is:
https://www.amazon.com/Diageng-Right...=odb2+splitter
Also 4.10s are on the way!!
Edit, 4.10s never happened. I want to the dark side: Auto.
Old 09-06-2017, 10:20 PM   #24
Chevy71
Chevy71's Avatar
Drives: 2016 2SS
I don't think you are understanding how a GMR pick up works. It works on any car that sends a signal to fire through a wire. It's picking up voltage going though the wire. I really don't see how it couldn't work
Wow here it is:
Forged pistons
667rwhp 577ft lbs
Old 09-07-2017, 06:40 AM   #25
Fraxum
Fraxum's Avatar
I understand that part. But is there a distinct signal? Wouldn't that pulse a test light?
I guess I could spend $60 to find out. I've wasted so much money on cars what's another $60.
Awesome build BTW. You will be way into the 10s once you get it sorted.
Old 09-07-2017, 05:42 PM   #26
Chevy71
Chevy71's Avatar
Drives: 2016 2SS
I'll let you know later tonight how it works. It's really just using a pulse to sense the coil signal wire and using that pulse for RPM. You are right in that the signal is weaker on these than older style engines, but you can set the PPR to .5 and turn your GMR up and have no issues. I use GMR pick ups at work on heavily insulated wires that send extremely weak feedback signals and have no issues reading them. I think we will be alright with this, but I'll let you know for sure later on. As soon as I find a website with the VSS wire on a diagram, I'm going to head down and hook my light up. This way you'll know for sure before buying it.
Forged pistons
667rwhp 577ft lbs
Old 09-13-2017, 06:46 AM   #27
Fraxum
Fraxum's Avatar
Did you get a chance to try it?
Old 05-06-2018, 06:30 AM   #28
hogwild87
hogwild87's Avatar
Drives: 2016 2SS Camaro
I just installed my raptor last night and i couldn’t get it to work and i attached green wire to pin C on #1 coil blue wire with purple tracer and had ppr set to 8 cylinder mode. I even tried the 1/2 ppr and I believe it went into error mode
hogwild87 is offline   Reply With Quote
