Old 03-09-2016, 10:21 AM   #29
Tr6
The Dogfather
Drives: #1 off the line for a customer. '16
Originally Posted by usmcfiredog View Post
So where did you run the wires for your setup? How much of the dash and roof did you have to take apart? I am loving my Max 360 also, already saved me from 2 tickets so I think it has paid for itself, lol. Do you have any pictures of your install?
I had mine installed, didn't do it myself as last time I tried to do LED DRLs on my car and the first time doing electrical work, I burnt myself and have a mark for life on my left hand now LOL. It's installed on the BCM accesories port which is under somewhere the driver side. Then the wire was carried from the bottom to the A pillar and then straight across behind the roof liner.
Originally Posted by Chad's ZL1 View Post
when they say "red or blue" hard wire kit, are they just talking about what color the light lights up when it alerts?
Yes he is. On escorts website and amazon they have 2 and it is just the LED color
Yeah, what usmcfiredog said. Blue or red is just the color of the mute screen. I went with red as my interior is adrenalin red + max360 you can change the screen between 4 colors of your choosing and made mine red. With the accent lighting, everything came together.
A MASSIVE suggestion that I will make is when/if you get the mute hardwire, black sharpie the green light that is always on the mute button (thank you Kracka for the suggestion!). Because it's way too damn bright, but if you just use a black permanent marker Sharpie, you will STILL see the green light but it won't be like a freaking stadium flood light in your face.
2SS, Garnet Red with Adrenalin red, NPP, MRC M6 coupe
#33 off the line #1 order for Customer.
Build thread HERE!
Story of my delivery HERE!
Tr6 is offline   Reply With Quote
Old 03-19-2016, 11:52 AM   #30
usmcfiredog
Drives: 2016 Black 2SS
I just installed the mirror tap and it threw me for a loop because the wires that I used are only on when the car is running and not with accessory power. So checking to make sure I installed correctly was painful until I figured it out.
Camaro 2SS
Black/Jet Black
A8, NPP, MRC, NAV
Low Gloss Black 5 Spoke
usmcfiredog is offline   Reply With Quote
Old 03-19-2016, 04:48 PM   #31
stella16
1959 Chevy Apache 4X4
stella16's Avatar
Drives: 2017 ZL1
TR6, I also have the Max 360. Which blendmount bracket did you get? And just the basic smartcord direct kit?
thanks
stella16 is offline   Reply With Quote
Old 03-20-2016, 12:55 AM   #32
usmcfiredog
The blend mount for the camaro is the same as the c7 vet and the 15inch wire. On blend mounts website it tells you which to get for the camaro
Camaro 2SS
Black/Jet Black
A8, NPP, MRC, NAV
Old 03-20-2016, 09:05 AM   #33
Luigi91
Their website does not list anything for the Camaro. The one for the C7 Vette is correct though. I spoke directly with Blendmount, and once I send them pictures to verify correct installation, they will be updating their website and Amazon listings.
Luigi91 is offline   Reply With Quote
Old 03-20-2016, 09:55 AM   #34
stella16
stella16's Avatar
Drives: 2017 ZL1
thanks. I will get mine ordered !!
Old 04-03-2016, 02:04 PM   #35
Adrian97c
Adrian97c's Avatar
Drives: Wife's 14' IS 250
Great thread.. Looking into my 1st detector ever, Max360.. Also like the blendMount/MirrorTap clean install!
-11% tint all around
Ordered • 2/06/16
Built on • 3/22/16
Adopted • 4/07/16
Sold on 2/05/16:
-Borla ATAK catback
-Range AFM delete
-15% tint all around
-Red LED interior bulbs
-55k white Cree LED fogs
-License plate LED bulb swap
-12" Sub Kit, BA amp swap
Adrian97c is offline   Reply With Quote
Old 04-06-2016, 07:58 AM   #36
NEGXXIS
NEGXXIS's Avatar
Drives: 2019 Camaro SS A10
Thanks for posting, saved me time no having to probe wires..lol Hooked mine up yesterday
2020 Range Rover Sport HSE P525 Supercharged 5.0 - Firenze Red - 9012 wheels
SOLD 2019 Camaro SS -Wrapped in Matte Magnectic Black - Anderson Carbon Hood and Rear Spoiler – Ikon front spoiler – OEM ZL1 Side Rockers - ZL1 Addons Diffuser - BMR 1.0” Lowering Springs - MRR 228 Wheels 20x10 and 20x11
RIP 2016 Camaro SS https://www.camaro6.com/forums/showthread.php?t=565453
SOLD 2010 Camaro SS Featured in GM High Tech Performance and Camaro Now Magazines - http://www.superchevy.com/features/g...of-perfection/
NEGXXIS is offline   Reply With Quote
Old 04-17-2016, 05:20 PM   #37
Adrian97c
Adrian97c's Avatar
Originally Posted by Tr6 View Post
I had the red mute hardwire kit from Escort hardwired about a month ago for my 9500ix. I do like the concept behind MirrorTap but having to reach and click the radar detector every single time to mute is not something that's great. I really am liking the max360. It is pretty legit. A bit overkill if you ask me over the 9500ix as that got the job done MANY times but I said screw it and upgraded. Can't go wrong with it, that's for sure. Especially since the only pro of V1 over the escort were arrows and the 360 has it, so there is absolutely no need for any valentine detectors haha.
The placement of the mute button worked out perfectly too.
Why reach to the detector? I'll be using mirror tap, but will use the EL app on the phone to mute. I might even get a gooseneck phone holder that plugs into cig lighter port or something.
Ordered • 2/06/16
Built on • 3/22/16
Adopted • 4/07/16
Sold on 2/05/16:
-Borla ATAK catback
-Range AFM delete
Old 04-18-2016, 06:40 PM   #38
Adrian97c
Adrian97c's Avatar
Too bad the Escort live app doesn't switch to Bluetooth for voice alerts! For example if listening to XM/FM you won't hear alerts through car speakers unless you are in Bluetooth mode already. WAZE switches to BT, then back to XM.
Ordered • 2/06/16
Built on • 3/22/16
Adopted • 4/07/16
Sold on 2/05/16:
-Borla ATAK catback
-Range AFM delete
Old 04-18-2016, 11:28 PM   #39
DougCBJ
Drives: 2016 Blue 2SS
it doesn't work correctly because the app needs an update after the latest iphone update. It's annoying that they take so long to make updates. I pay 650 for a product that doesn't function fully. I can't have the radio up or I'll miss alerts now...
DougCBJ is offline   Reply With Quote
Old 04-19-2016, 06:31 AM   #40
Adrian97c
Adrian97c's Avatar
How To Hardwire your radar detector by Tejesh83
Hoping for an update... Also want to edit my post above.. WAZE sometimes doesn't switch back to XM, it'll force me to have to switch back to XM.. What I mean is that WAZE will alert me (by switching to BT), then the car audio stays in BT/iPod mode.
So I'm dealing with both of these issues from WAZE & ET.
Doug, could you confirm what iPhone & iOS version you are running?
Ordered • 2/06/16
Built on • 3/22/16
Adopted • 4/07/16
Sold on 2/05/16:
-Borla ATAK catback
-Range AFM delete
Old 04-19-2016, 02:30 PM   #41
DougCBJ
5S 9.3.1 (13E238)
Old 04-19-2016, 02:56 PM   #42
Adrian97c
Adrian97c's Avatar
5S 9.3.1 (13E238)
So you can confirm that prior to the most recent EL app update, the alerts would carry over car speakers even when listening to XM?
Ordered • 2/06/16
Built on • 3/22/16
Adopted • 4/07/16
Sold on 2/05/16:
-Borla ATAK catback
-Range AFM delete
