Old 06-04-2020, 02:52 PM   #1
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Will these wheels fit my SS
I know look at the previous posts. Didn't seem these were out of specs to fit I decide to go 19" SQUARE setup....
Wheel Size : 19x9.5
Bolt Pattern (inches) [?] : 5x4.72
Bolt Pattern (metric) [?] : 5x120
Backspace : 6.25 inches
Offset [?] : 25 mm
Full Finish [?] : Gloss Black
Center Cap : Included
Old 06-04-2020, 05:15 PM   #2
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
Wheel Size : 19x9.5
Offset [?] : 25 mm
These should be no problem. I am running APEX SM10 19 x 10.5 ET22 wheels on all four corners and the wheels you selected are 1 inch narrower than mine. I am assuming you are going to run 285 19 tires all the way around?????
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 06-05-2020, 06:26 AM   #3
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Thank you. Have not figured the tires out yet. Thats actually bigger size so I will look at that. Maybe some Firestone Indy or General AS05.
Old 06-06-2020, 02:53 PM   #4
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Firestone Indy 500 Firehawk 285/35/19 looks like a good fit. The Tires will be sticking out about 14 mm farther in the rear. Will this be an issue with rubbing?
Old 06-07-2020, 08:23 AM   #5
sr71bb
sr71bb's Avatar
Thats just a little more than 1/2 inch. Thats not going to be a problem
Retired Cars BELOW:
Old 06-11-2020, 12:21 PM   #6
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
OK so i took the plunge....$ 479 for 4 shipped to my door....
Old 06-25-2020, 08:31 AM   #7
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Wheels arrived.
Old 06-29-2020, 09:27 PM   #8
asthmamax11
asthmamax11's Avatar
Good deal
Where did you order those wheels from ?
16 1SS M6 White
Magnuson 2.3 Heartbeat
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
02 Z28 M6 35th anniversary
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 07-01-2020, 08:11 AM   #9
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Originally Posted by asthmamax11 View Post
Good deal
Performance Plus tires...google it
