08-15-2018, 03:54 PM | #1 |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
Upper/lower control arm bushings on ZL1 1LE compared to ZL1/SS 1LE
Other than the obvious of DSSV shocks, spring rates, sway bars, and the solid rear-end, are there differences in the suspension of the ZL1 1LE compared to the ZL1 and SS1LE for bushings in the upper/lower control arms?
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
08-17-2018, 09:29 PM | #2 |
Drives: '16 2SS GD1 MX0 NPP F55 IO6 Join Date: Jun 2013
Bushings? The ZL1 1LE IRS doesn't have rubber bushings like the rest of the Camaros. Either solid mount or billet aluminum replaces your rubber bushings.
08-17-2018, 11:15 PM | #3 |
It has bushing in the arms. The rear cradle is solid , but it still has bushings elsewhere.
Current:
08-18-2018, 07:48 PM | #4 |
Drives: Chevrolet Camaro SS Join Date: Mar 2015
This thread covers the part numbers, FE4/FEA share a lot of parts. The OP bought the zl1 1le handling kit (mentioned below) but sold it because of all the similar parts.
https://www.camaro6.com/forums/showthread.php?t=522102 From Chevrolet Performance "THE LINK YOU’RE MISSING The perfect pair to the ZL1 1LE Spec Multimatic Lowering and Handling Suspension Upgrade System (P/N 84352121), this competition use† only, track-tested ZL1 1LE Spec Handling Component Suspension Upgrade System provides racers with front ride links, front handling links, rear upper and lower trailing links, and rear knuckles complete with stiffer bushings and ball joints to reduce suspension flex. The 71% stiffer upper and lower trailing links (compared to the Camaro SS), 58% stiffer rear link inner bushings, and an additional 4% reduction in roll gradient (combined with the ZL1 1LE Spec Multimatic Lowering and Handling Suspension Upgrade System), result in improved on-track performance lap after lap. For competition use only†." |
08-18-2018, 08:35 PM | #5 | |
If I need to go further, I will go with the BMR rear upper control and trailing arms.
Current:
08-18-2018, 09:58 PM | #6 | |
It's been fun, done with GM.
2018 Camaro ZL1 (SOLD) - Blown Airbags 2017 Camaro SS F1FTY Member Journal (SOLD) - Bad Motor |
12-14-2018, 09:16 AM | #7 |
Drives: 2018 Camaro SS 1LE Join Date: Nov 2018
So has anyone fitted this ZL1 1LE Spec Multimatic Lowering and Handling kit on their SS 1LE yet? If so, what were the results and will it actually fit with our mag ride? I'm assuming this will alter the geometry for a higher roll center when lowering (compared to stock SS parts) as well since the ZL1 1LE can be lowered. I'm considering this along with either BMR springs or KW V3 coilovers and a camber plate for an autocross alignment setup.
12-14-2018, 01:14 PM | #8 | |
Drives: 2017 1SS 1LE Join Date: Jun 2016
As for if anyone's done it yet, one user here has done it here on a ZL1 which is essentially the same suspension as the SS 1LE. The kit doesn't alter geometry with the exception of having adjustable front strut top mounts for more negative camber and slightly different caster. All of the body-side points and lower ball joint remain in the same location as they do on the SS 1LE. Lowering is just resting at a slightly more "jounced" position compared to stock.
2017 SS 1LE.
Thread Tools | |
