03-06-2017, 01:57 PM | #1 |
Drives: 2016 Camaro 2SS Nightfall Grey Join Date: Feb 2017
Rear Diff Broken and Cause two trannys to go
I have a 2016 2SS with 14,394 miles on it. In August of 2016 I took my car to the dealership with 10,146 miles because I noticed smoke coming from my tailpipes and oil covering the rear of my car. Dealer looked at the car and said "Checked for leaks, none present, but the vehicle was 1/2 Qt Low". I was given the car back the same day. Went back two weeks later with 10,611 miles and was told that the differential oil cooler outlet hose had a "poor fit". They replaced it and returned the car back to me 8 days later. I still continued to notice the smoke coming from my tailpipes and the oil on my rear so I went to the dealership numerous times just to be told "don't worry about it its just burning off the rest of the oil that leaked before the repair". I stupidly listened to what they said. Then in October I brought the car to the dealership again, this time with 12,360 miles because I was still having the same problem but now I was also having transmission issues and a horrible engine whine. The car would not go into gear at some points. They said they found the mainshaft bent and since GM was not in production with the parts needed to fix the tranny they just replaced the whole transmission and returned it to me almost a month after. Then December came. The car has 14,353 miles on it. The car STILL continues to leak oil. The dealership looks at the car for just a few minutes and tells me the car is leaking rear differential fluid from several seals and fittings and then told me that my "rear is shot" and said they weren't going to cover it. BECAUSE MY TIRES WERE LOW ON TREAD. The car sat there till February and then I decided to take the car and have someone else fix it because I was fed up with Chevy. The day I pick up the car while on the highway just cruising I decide to downshift to 4th and it would not go in. I was locked out of all my gears! I finally got the car into 4th just for it to suddenly pop out a minute later. I then put my clutch in got my car into 3rd but my clutch would not come back up. I painfully smelt the burning of my clutch, pulled over and turned off the car. I then had the car towed from a nearby spot right off the highway back to the dealership. They looked at the car and all of a sudden I now I have no fourth or second gear. And they still refuse to cover it because of some bald tires. What do I do? I love this car but I can't deal with the stubbornness of GM. PLEASE HELP!
03-06-2017, 02:04 PM | #2 |
Drives: 2016 Summit White 2SS (Auto) Loaded Join Date: Jul 2016
Take it to another dealer
03-06-2017, 02:34 PM | #3 |
Drives: Chevys at the limit Join Date: Nov 2010
WHAT IN THE ACTUAL?!?! WHAT?!?! They won't fix your car that has been having the same issues for months because of some tires?!!? You need to take that to a different dealership and talk to someone that can actually help you out. I have heard of powertrain warranties going out for some simple things but tires?? Really?!
Keep us updated OP. Best regards, Kayla L. 801.545.4215 |
03-06-2017, 03:12 PM | #4 | |
03-06-2017, 06:48 PM | #5 |
Drives: 2016 Hyper Blue 2SS A8 Join Date: Nov 2016
Something's not right here.
03-06-2017, 07:36 PM | #6 |
Drives: 2016 1SS 6speed Join Date: Mar 2016
Start blowing up GM's corporate customer service lines. They called me a few months after I snapped an axle making sure everything was taken care of. You still have a power train warranty, assuming it's still stock. Tire wear has nothing to do with it. On top of that it's a known and documented problem. Definitely take it to another dealer, since the one you bought it from obviously doesn't care. They also send out surveys reguarding their service. Make sure you fill that out and give them the lowest possible rating. The more people that do that, the less likely GM is to allow them to keep their Franchise.
2016 1SS M6 P1SC Stg II 592rwhp/548rwtq (for now)
GForce Outlaw axles & driveshaft, TSP 2” LT’s, turndowns, RTS S71 drag pack with radials. |
03-07-2017, 09:45 AM | #7 | |
03-07-2017, 10:02 AM | #8 |
Definitely talk to a lawyer. Try to find someone that specializes in lemon law and similar issues. They'll be able to tell you exactly what your options are.
03-07-2017, 01:02 PM | #9 | |
Nick |
03-07-2017, 03:28 PM | #10 | |
03-07-2017, 04:56 PM | #11 |
Speaking from experience.....5K launches on slicks don't hurt the rearends or the trans.
Guaranteed something was wrong from day 1. I'm even 90% positive that 5K launches with an additional 150 hp aren't going to hurt either of them. I only say 90% since I haven't done it yet and I don't foresee even needing to. It'll probably be more like 4K....
03-08-2017, 03:34 PM | #12 |
Drives: 2016 Camaro 1LT Join Date: Apr 2016
Buy some new or used back tires and try a different dealership. Kind of joking but kind of not. Sorry man. Dealing with these things suck.
03-09-2017, 02:46 AM | #13 |
The Doctor is in
Drives: 2016 Camaro 2SS Nightfall MRC NPP Join Date: Jan 2016
Yeah i'm going to have to agree with OP unless we are missing something. Uneven sized tires (not just wear) can cause differential issues, but not transmission issues. Worn tires at 14k miles is, well, normal. My GYs were toast at about 9k, but that is with a few autocross events on them. Per GM, if you take it to the track, you are still covered under warranty. Where in NY are you located (you can PM me if you want)? I had the worst customer service experience at one of my local Chevrolet dealers.
03-09-2017, 08:47 AM | #14 |
PC Technician
Drives: 2016 Hyper Blue 2SS Join Date: May 2012
Have you thought about reaching out to the local news? Publicity can really get things working in your favor.
Tags |
gears, help me, manual transmission, rear differentail, warranty |
Thread Tools | |
