03-02-2016, 12:03 PM | #1 |
Drives: 2011 2SS Join Date: Mar 2015
3.91 gears questions
I'm planning on having 3.91 gears installed on my car once I know we won't have any more rain (hopefully soon). I saw the gears on phastek for $309.95, and the install kit for another $200. Do I need the install kit? What does it do? How much should I expect to pay for labor? Will it improve my 0-60, and by how much? Thanks for your input everyone
03-02-2016, 12:14 PM | #2 | |
Drives: Black L99 2SS/RS Join Date: Mar 2014
http://www.camaro5.com/forums/showthread.php?t=281654
03-03-2016, 11:32 AM | #3 |
Do your self a favor and avoid after market gears, GM gears are nominal and chances of winding up with a howler are greatly reduced.....
https://chevroletperformanceparts.co...r-kit-19301504
2015 2SS/RS Crystal Red, Z28 CAI, Borla S Type axle back exhaust, LE Gear upgrade.
03-03-2016, 12:17 PM | #4 | |
Drives: 2012 2SS/RS LS3 Join Date: May 2012
Victory Red 2012 2SS/RS LS3 Camaro
Pat G. Spec Cam from Cam Motion 228/236 .599/.599 112+2LSA Kooks 1-7/8" LTs w/ Cats Roto-Fab, Bo White TB, Borla Touring Catback 3.91 1LE Gears, MGW Tuned by Pat G |
03-03-2016, 01:33 PM | #5 | |
03-03-2016, 01:53 PM | #6 |
drinks virgil's
Drives: 2010 2SS M6 Join Date: Feb 2014
Can't speak for 0-60 as I haven't measured. Seat of the pants is definite.
Not sure if the Phastek kit comes with the speedometer recal code or not either. The GM kit comes with one or if you get it through Janetty apparently he can do it as well. Cheapest route is to buy the gears and install yourself. If you can't, then pull the pumpkin and take it tome someone to install and put the pumpkin back in yourself. If you can't do that either, the dealer is going to cost you $1500 or so for everything.
2010 2SS/RS M6 - CAI Intake - Borla Stinger - VTC - 3.91's
Eibach Sways - LG ZR28's - BMR Springs - 285/35 Squared |
03-03-2016, 02:31 PM | #7 | |
03-03-2016, 02:41 PM | #8 | |
drinks virgil's
It's not hard to pull the pumpkin and take it someone. Just make sure they set the preload to spec and the backlash is good.
03-03-2016, 04:34 PM | #9 |
03-03-2016, 08:04 PM | #10 |
Got my set from Muareen from Rodgers Chevrolet best price anywhere!!!
Orange Krush II
03-03-2016, 08:28 PM | #11 |
old school chevy rodder
Drives: 2013 2SS/RS Manual,DM exhaust,CRT Join Date: Jul 2012
the kit is for the new bolts sometimes needed for the differential and the shims that are necessary to install to adjust it just right also new bearings are good, as is a LPW diff cover and poly bushings for the diff at least with the rear.
03-03-2016, 08:44 PM | #12 |
Thanks for the info!
03-03-2016, 11:29 PM | #13 | |
08-11-2016, 08:45 AM | #14 |
I just had a shop give me a quote and they said with my mileage, 59k, I might want to do the bearings as well. What bearings is he talking about? All I see in this kit are shims/spacers and a crush sleeve.
Tags |
0-60, 3.91 gears, 3.91 kit, gear swap, gears |
