11-20-2015, 12:20 PM | #15 |
Drives: '13 2LT/RS Twin Turbo Join Date: Aug 2012
That's always been my advise, if you really want to go turbo just run the kit by itself. If your worried about it just don't buy a boost controller and run 7-8psi on the springs.
3.6L Twin Turbo V6 Garrett GT28 turbos -- Jacfab forged connecting rods -- Diamond forged pistons(10.5:1) -- Alky Control Methonal Injection -- CircleD 2E triple disc torque converter -- BMR suspension 10.75 @ 131mph |
11-21-2015, 02:58 PM | #16 |
Drives: 2015 2ls Join Date: Sep 2015
what are the options available or most recomended for just more street performance on an 2015 lfx auto?
11-21-2015, 04:10 PM | #17 |
Drives: 2013 Camaro 1LT Join Date: Jun 2015
Turbo setup I would stick with 3.27's for a daily driver. If you want to get more serious about racing I would go to the 3.45 setup so you'd have a locking diff. I wouldn't go any deeper than that. Turbos like load.
Elite catch can & clean side oil separator, Apex Scoop, CAI cold air intake, Vmax ported throttle body, TTT ported intake manifold, JacFab intake manifold spacer, Magnaflow cat back exhaust, Weld RT-S 17x5 f and 17x 9 r wheels, MT 28/6/17 f and M&H 275/50/17 r tires, TTT rear seat delete, Nitrous Outlet plate kit, 125hp jets.
11-21-2015, 04:20 PM | #18 |
My opinion is that for a naturally aspirated, non-power adder, V6 Camaro a rearend swap with 3.45 gears is the setup. 28" drag radial and these gears would have you going through the traps at the drag strip around 6600 rpm in 3rd gear. With a better converter you would probably be around 6800. That means it would be fun on the street!
11-21-2015, 04:53 PM | #19 | |
11-21-2015, 05:23 PM | #20 |
Rearend unit swap sounds the easiest and most cost effective to me.
11-21-2015, 05:36 PM | #21 | |
Drives: '14 1LS Join Date: Apr 2014
That directed to me? Don't I have a locking diff with the 1LS? Sent from my iPhone using Tapatalk
Patiently waiting for my 2023 SS 1LE |
11-21-2015, 05:47 PM | #22 |
Maybe you do. I Can never remember all the differences between models. I know mine has an open diff... I was mostly referring to the ratio.
11-21-2015, 06:39 PM | #23 |
What's the torque rating on the rear end 1ls vs ss?
Tags |
gears, lfx, turbos |
