Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 03-24-2011, 06:45 PM   #15
JM10
Se habla espaņol
JM10's Avatar
Drives: 2010 Camaro SS/RS VR
Mine is a M6...
Guess that I will have to go to LPE 3.70 Gears...seems that they are stronger than richmonds...(at least before the release of their "new" 4.10s)
JM
2010 VR 2SS/RS
BMR Suspension Parts
Hendrix HD Axles
DSS Aluminum Shaft
RPM Diff / 3.91 Gears
LPE ZR1 Clutch
Edelbrock E-Force SC / JRE Fuel Upgrade
Livernois 1C cam 570 rwhp/559 rwtq SAE
Best 1/4 time: 11.43
JM10 is offline   Reply With Quote
Old 03-24-2011, 06:48 PM   #16
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Originally Posted by JM10 View Post
Mine is a M6...
JM
There have never been any issues with the Richmond 3.73, it was isolated to the old 4.10.
Apex Motorsports is offline   Reply With Quote
Old 03-24-2011, 11:05 PM   #17
OBSSEST
Drives: 2010 Camaro 2SS RS, Black
Originally Posted by white_screamin_ss View Post
Iv got an ss auto with cai, full exhaust, underdrive pulley, ported throttle body and intake manifold and soon to be jannetty custom tune. What would u recommend for me to get a little more pep without losing to much mpg?
Get your tune first and then reassess what you need the car to do from there.
OBSSEST is offline   Reply With Quote
Old 03-25-2011, 01:38 AM   #18
JM10
Se habla espaņol
JM10's Avatar
Ive changed my mind and decided to wait for the 3.90s
JM
2010 VR 2SS/RS
Hendrix HD Axles
DSS Aluminum Shaft
LPE ZR1 Clutch
Old 03-25-2011, 08:37 AM   #19
Apex Motorsports
JM
Shoot me a PM titled "I want 3.90s!" and I'll let you know as soon as we get them.
Old 04-03-2011, 12:30 AM   #20
mpiper
mpiper's Avatar
Drives: 2011 Black 1LT RS
Has anyone dropped a Manual (Posi) rear into an Auto V6 yet? Any issues?
mpiper is offline   Reply With Quote
Old 04-03-2011, 03:35 AM   #21
TRC-SS
700RWHP-650TQ
TRC-SS's Avatar
Drives: 2011 Forged LS3 Supercharged/Cammed
There was no mention of this...but on a basically stock car(HF cats, SW Retro Catback, intake)....will these work with out a tune? say 3.73 or 4.11s essentially your odometer will spin faster with out a tune...am i on the right path?
View Build HERE>>>>>MY 2011 2SS/RS JOURNAL
TRC-SS is offline   Reply With Quote
Old 04-03-2011, 07:50 AM   #22
Apex Motorsports
Not that I am aware of. It wouldn't be a simple swap, there would have to be some custom fabrication to make it work.
Old 04-03-2011, 07:51 AM   #23
Apex Motorsports
You do need to recalibrate the speedo.
Old 04-03-2011, 08:24 AM   #24
mpiper
mpiper's Avatar
What parts are different? I was under the impression the suspension was the same, so I was hoping you just swap differential cases. Here's my thought process, just point out the necessary changes I've missed. I'm not in a hurry to do this, since I want the drivetrain warrantee a whioe longer, but I plan on doing it sometime in the future.
Version 1 ( same axles for non and posi)
1. Remove axles.
2. unbolt Diff. Case
3. Slide case out and off Driveshaft.
4. swap cases
5. reinstall old axles
Version 2 ( axles are different and match differentials)
1. Remove axles
2. Remove diff. case (and all related steps)
3. install new/swap diff. case
4. Install axles from Swapped Diff. case
So I was thinking you could reuse the entire rear section except differential case and maybe axles. I saw an entire rear subframe (diff, axles, full suspension system, etc.) on ebay.
Here is the link
Are you saying that entire structure would need to be swapped?
I was hoping to buy just something like this one. (Not from ebay, just an easy way to illustrate my thoughts.)
Last edited by mpiper; 04-03-2011 at 08:27 AM. Reason: Found second example on ebay.
Old 04-03-2011, 08:51 AM   #25
Apex Motorsports
This was studied in depth early last year. I can't find all the info right now but if I remember correctly there was something about the drive shaft being different and not being able to work. Not a hurdle that can't be overcome, it would have to be a custom fabricated piece, but that will stop it from being a simple bolt up swap.
Old 04-03-2011, 11:57 AM   #26
mpiper
mpiper's Avatar
So, If I were to swap the differential, I'd need a new Driveshaft since the gap between auto trans and posi trans is unique. I would have thought I'd need a drive shaft from an auto SS, but I guess the two auto trans aren't the same length?
So that's it? posi differential housing and custom driveshaft? Or is there more?
Old 04-03-2011, 08:41 PM   #27
Apex Motorsports
I'm going to have to try and find all the info again because I can't remember the specifics. What I can remember is that it can't be pulled off with off the shelf parts.
Old 04-05-2011, 10:27 PM   #28
mpiper
mpiper's Avatar
I'm subscribed. One of my long term goals is to drop a posi 3.7/3.73 rear in. No rush, I want the warranty a bit longer on the stock drive-train so if anything breaks in the first year to 25k miles it's covered, but after that, the posi's going in. So as long as we have a solution, even if it's a custom drive-shaft or something similar, I'm game.
Last time I did this (with a 79 Grand Prix, so no comparison), I just took the stock drive-shaft, had the shop make measurements and a local shop did the cut&weld to give me a custom drive-shaft from the stock original. I'm hoping to do the same with this one.
3.73, 4.11, gears, rear differential, rear end gears
Richmond Gear Camaro gears RichmondGear V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 85 01-19-2015 10:43 AM
Tune, gears, warrantee, all that stuff again...but f5journal Tuning / Diagnostics -- engine and transmission 6 02-25-2011 10:13 AM
Why does Camaro have lower skidpad numbers than CTS-V? OldJedi Suspension / Brakes / Chassis 9 06-22-2010 06:00 PM
Fastlane Tune - Are these numbers good? Dangeruss Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 58 03-14-2010 11:38 PM
Thinking of Painting my Camaro. Scott@Bjorn3D Cosmetics and Lighting Modification Discussions 24 12-26-2008 04:59 PM
