10-23-2020, 08:43 PM | #1 |
Drives: 2017 50th Anniversary SS Join Date: Mar 2016
How to upgrade 2SS to 1LE
I was wondering what needs done to a stock 2SS to add the 1LE package?
!. suspension upgrade. 2. Wheels. 3. 6-piston Brembos Anything else? Starting with a 2017 2SS with Mag shocks, NPP exhaust and A8. I don't care about cosmetics i.e. seats, hood, mirrors or spoiler satin paint just the performance mods. |
10-23-2020, 09:08 PM | #2 | ||
Drives: On Hiatus Join Date: Apr 2020
In anycase, from the sticky: Quote:
10-23-2020, 09:26 PM | #3 | |
• Segment-exclusive electronic limited-slip differential with 3.73 ratio • Available PDR video/data recording system. The PDR has third party alternatives, but the e-diff cannot be swapped in. (Coolers are the same as on the standard SS.) The spoiler and especially the splitter are also performance mods. Now as to how much these contribute to a car's "1LE-ness", the jury is still out. Obviously, 1LE owners will say the e-diff and its associated PTM driving modes make all the difference in the world, but my car has a lot of the 1LE goodies—and if I'm brutally honest, my driving skills are not at the point where I would seriously be hampered by the lack of these two above, so for someone with little track experience the e-diff may not matter that much. My car is already tangibly superior to a standard 2SS due to the upgrades applied.
2018 Camaro 2SS G7E MX0 NPP F55 IO6
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 10-25-2020 at 11:29 AM. |
10-24-2020, 02:26 AM | #4 | |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
Dual purpose car
Suspension Kit Part Number 84203549 (shocks, springs, etc.) and the SWAY bar kit part number 84401188. This is more commonly referred to as the SG3 suspension. Note: My SS DID NOT have MAGRIDE so the part number for the spring upgrade MAY be different. MY own car is a BLACKED out 2019 Camaro SS2 with A10. AMP installed an upgraded wheel and tire package that included APEX SM-10 19 x 10.5 wheels wrapped in Michelin Sport 4S 305 30 19 tires. This combo is ROTATABLE and with currently has 9K miles on them , the tires show only about 30% wear so far with about 20 20 minute track sessions. VORSHLAG camber plates were installed which allow be to go from my STREET alignment FRONT wheel settings of -2.2 degrees negative camber to 3.6 degrees negative camber in a matter of about 10 minutes at the track. I run also -2.2 degrees negative camber on the REAR for both street and track use. I ROTATE the tires and wheels every 2500 miles or so. AMP installed ZL1 brakes (15.3 inch front rotors) on the front and the rear of the car (special note: The SS brake package is the SAME as the ZL1 brake package on the REAR of the car so the improvement in braking is due to the front brakes ONLY. I have NEVER noticed any amount of brake fad at the track even when braking VERY hard. POWER improvements by AMP push the power to the 500HP range but additional upgrades should make this around the 580HP level NA with NO associated issues with supercharger heat soak issues. The car is ABOUT 250 pounds LIGHTER than a ZL1 so even using the dual purpose MS 4S 300 treadwear tires, the car handles EXTREMELY well and is absolutely NEUTRAL in its handling characteristics. Car is used as daily driver and is considerably more fun to drive as a dual purpose car than the ZL1 1LE that I had for a short period of time. PLUS the car doesnt ride like a dump truck when used as a daily driver on city streets.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
10-24-2020, 04:09 AM | #5 |
Drives: R.I.P. 2021 ZL1 & 2019 Rd Garn 2SS Join Date: Dec 2019
Okay guys I have a question. I have a 2SS it has the 1LE track package no the 1LE. It's a M6, has NPP, Mag ride and Recaro racing seats my question is do I have the ELSD or the 3.73 gear ratio.
10-24-2020, 08:10 AM | #6 |
Drives: E92 BMW M3 Join Date: Oct 2012
If it is not a Factory 1LE you do not have the eLSD.
J-Rod Built and Matt@FSP Tuned |
10-24-2020, 09:00 AM | #7 |
shoe, I know you don’t really want to hear this but if I was wanting to mod my 2SS with 1LE parts, I would look for a used 1LE optioned SS to replace my 2SS with. Sure you can add most of all the parts but it won’t be cost effective and you still won’t have after you’re done a true SS 1LE Track Camaro. Those Recaro seats are nice in the 1LE and of course the eLSD is good too. I do understand what you are wanting to do and as mentioned you could buy the Chevy Performance parts 1LE Track Pack kit for your SS and get a nice set of aftermarket wheels/tires and that would make a difference in the suspension of your SS. I think Chevy even offers with that suspension kit a reprogram for the 2017 and 2018 SS suspension once it’s installed in your car. As others have replied there are ways to get to your goal of a better handling 2SS and just search around on the internet to get ideas. Good luck with your project!
10-24-2020, 09:02 AM | #8 |
Drives: 2020 SS1LE Shadow Gray Metallic Join Date: Feb 2018
No you do not have the Elsd and 3.73 gears and I am not sure if anyone has successfully added those a non 1LE car.
10-24-2020, 06:12 PM | #9 |
I have a 50th edition and don't want to part with it. I like the idea of a 2SS 1LE Auto.
10-24-2020, 09:33 PM | #10 |
You definitely have a very special car. Doing what I did, inching the car towards a 1LE, you'll definitely have paid more in the end than if you'd ordered a 1LE, but you can pick and choose which parts you want. True, the result will never be a true 1LE, but you still can get pretty close.
10-24-2020, 10:28 PM | #11 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
A couple of points/thoughts:
Also, side note, the option to have auto 1LE's is also coming from GM if you haven't seen it yet. It obviously won't have the 50th specific cosmetic details, but seems like it gets all the performance things you want integrated out of the box.
2017 SS 1LE.
10-25-2020, 04:58 AM | #12 | |
As far as what you're missing by not having the eLSD and PTM, Chevy did a test where they modded a regular SS with their 'lowering kit' consisting of springs and shocks, added the 1LE handling kit (sway bars and links), plus added the 1LE tires/wheels. Was not mentioned whether the SS had the base 4-piston or optional 6-piston front brakes. The modified SS, while noticeably improved over stock, was still 2 seconds a lap slower around their track than the actual SS/1LE was. |
10-25-2020, 11:33 AM | #13 | |
With my driving skills, I'd personally take the 6+ second improvement over stock instead of trying to trade or sell/buy.
10-25-2020, 11:56 AM | #14 | |
I almost guarantee the OP won't go that route once he sees the costs of sourcing parts and labour to install all the components. He will have a "unique" auto 2SS 1LE that will be worthless on the used market, people want unmodified stock cars. Good luck though. |
