10-16-2020, 07:45 PM | #1 |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
Green Filter
I can’t find anyone who has a drop in Green Filter in stock for the stock airbox. Everyone has them on back order. Anyone know where to get one or will a K&N be just as good? Or, are they a waste of money compared to the stock filter?
10-16-2020, 09:22 PM | #2 |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
Mike I have a "used" green filter available, sitting in its original box inside another box sitting on the shelf in my garage, it has aprox 2,000mi on it (only fairweather street/highway driving)... If you really "want/need" one, PM me an offer with shipping cost included ...If not, NBD
10-16-2020, 09:25 PM | #3 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
Waste of money. Assuming replacement every 2 years with the acdelco a3223c, the Green Filter will finally pay for itself after 6 years.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
10-17-2020, 10:45 AM | #4 |
Drives: 2017 1SS 1LE...makes me go YeeeHaw! Join Date: Mar 2012
Green Filter didn't seem to do anything for me, at least anything I could physically notice, so I finally decided to install the Roto-Fab CAI and all is good now.
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late! |
10-18-2020, 07:35 AM | #5 |
If you buy it expecting to get more power in your SS, then yes, it's a waste of money as far as I'm concerned. Was tested by Jannetty on an SS and the green filter gained zero hp. I had a K&N in the stock airbox of my SS before and it did not gain any performance either.
10-18-2020, 09:15 AM | #6 | |
Drives: like an old lady Join Date: Jun 2012
10-18-2020, 09:40 AM | #7 |
There was a guy who put a Rotofab on his stock SS at the track and it went a tenth quicker with no other mods. So yea I wouldn't expect any big or noticeable gains changing anything on the air intake side for a stock car. Now once you do ported IM/TB, cat deletes or headers, then yea you will see some better gains...even more so as you do further mods that require more air flow.
2016 NFG 1SS A8
10-18-2020, 11:32 AM | #8 | |
BL1ZZRD
10-18-2020, 03:25 PM | #9 | |
car was: headers stock air box (cut) stock tb (unported) stock LT1 manifold (ported) added: rotofab (dry) 95 mm tb (unported) msd manifold (unported) car picked up 15 whp peak. curve was the same up to 5k then the new setup jumped up almost immediately. new setup carried power much farther (~6800 rpm). i was honestly expecting more given the fact that map kpa went from 93 to 99. i think it goes to show how well the pray ported LT1 manifold works. edit: mike, i think you bought that manifold, didn't you? i have proof it's legit haha.
10-18-2020, 04:41 PM | #10 | |
BL1ZZRD
10-19-2020, 05:20 AM | #11 |
if you modify the stock air box there is a good chance you'll have to scale the maf accordingly. my car ran like poop with a cut air box before it was tuned.
10-19-2020, 06:47 AM | #12 |
BL1ZZRD
10-23-2020, 09:43 PM | #13 |
Drives: 6 on the Flo' Super Sport Join Date: Jan 2011
I have a K&N green drop in..they probably help but not noticable. What some do is cut the bottom out of the air box. They say its good for 10 or 12 hp with the green drop in filter.
10-24-2020, 09:47 AM | #14 |
BL1ZZRD
I purchased a like new Green filter (slightly used) and dropped it in a couple days ago. I immediately noticed improved low speed drive ability especially in the 2-3k rpm range. WOT is awesome! So it seems that the Pray IM/TB combo likes the higher flow of the Green filter over the stock one. It’s still not perfect, still a slight lag around 2500 but much better! I’m going e85 soon so I might try the bottom airbox cutout trick before getting the tune.
Thread Tools | |
