TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LLT Engine, Exhaust, and Bolt-Ons
Old 05-21-2010, 04:10 PM   #15
Maurdib
Maurdib's Avatar
Drives: 2010 Black Camaro 2LT/RS Auto
Originally Posted by bbktech2 View Post
Camaroguy, you better be ready to pay up your bet. LOL! I've torn into a couple of V6 's for the header R&D and your gonna have more than a couple of hours in it. The hardest part is getting the bottom bolts off the stock manifolds. The heat sheilds can be a bit of a pain also. Use a wobbly 15 and long extension for the mid pipe nuts. A 3/8" drive impact really helps on the mid pipe/manifold nuts. The passenger side is the worst to take off. Just real tight on that side. Driver side is easier, remove the airbox to get the front lower bolt. I used 1/4" drive sockets, ratchet and various length extentions, they were easier to handle in the awkward position your hands need to be in. Both manifolds can come out the top when removed. Once you get the stock ones off your home free and the install is pretty much a piece of cake. Would highly recommend using a lift.
Would you have any dyno numbers with your CAI,LT/Highflow Cats all installed on a V6?
BackInBlack
Performance:Vararam cold air intake
Maurdib is offline   Reply With Quote
Old 05-21-2010, 04:32 PM   #16
camaro guy
camaro guy's Avatar
Drives: 2010 camaro LS
We shall see. I'm a b2 bomber technician and used to working in tight spaces.
camaro guy is offline   Reply With Quote
Old 05-21-2010, 06:43 PM   #17
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
Originally Posted by ROD1 View Post
They are getting about 25 additional HP.
I'm assuming this is to the crank?
BaylorCamaro is offline   Reply With Quote
Old 05-21-2010, 07:29 PM   #18
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
I would only hope 25HP. After a dyno the best is about 7hp.
Ihave the same headers with a solo exhaust.
Lets please be real !
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 05-21-2010, 07:31 PM   #19
mr_desmo
Drives: beated up old mini austin
as an aircraft mechanic ( canadian army) thats quite an aircraft...how is it to work on that baby? Such a gracefull piece of equipement!
mr_desmo is offline   Reply With Quote
Old 05-22-2010, 12:22 AM   #20
PieNsky
PieNsky's Avatar
Drives: Victory Red 1LS
Stainless Works has an available 1 3/4 tube that I now wish I had got. With the 1 5/8 tube and on 87 octane gas, I dynoed 167HP. I wasn't aware that it was pulling timing with the lower octane as the manual said to use it. Scrming noticed it would pull timing with the lower octane.
PieNsky is offline   Reply With Quote
Old 05-22-2010, 12:24 AM   #21
PieNsky
PieNsky's Avatar
And a shout out to SW. Get that chambered center section out for the long tubes!
Old 05-22-2010, 12:35 AM   #22
devildoc
devildoc's Avatar
Drives: '12 Toyota Tacoma Dbl
I couldn't have summed this up any better. Mind you this is a tech saying this. I'm an avg guy doing this. So everything he says is correct and I went about it the same exact way! So have fun if you don't have a lift or an impact drive.
STANDING 1/4MI: 13.948@99.87
6600RPM HP/TQ Gains - 30.54HP/24.3TQ (NOT PEAK)
devildoc is offline   Reply With Quote
Old 05-22-2010, 12:50 AM   #23
FutureCamaroOwner
FutureCamaroOwner's Avatar
Drives: White 1SS/Black Stripes
BBK claims it gets 33hp at the wheels. They dynoed it but we will see right. Mind you that was with high flow cats
FutureCamaroOwner is offline   Reply With Quote
Old 05-22-2010, 12:52 AM   #24
devildoc
devildoc's Avatar
Also that was mid-rpm not peak just remember that.....
Old 05-22-2010, 12:53 AM   #25
devildoc
devildoc's Avatar
You KNOW I will dyno here soon. The DA has gone up considerable so I don't want to risk throwing the dyno off to badly!
Old 05-22-2010, 01:09 AM   #26
mrray13
mrray13's Avatar
Drives: 2010 1LT RS Rally Yellow
Originally Posted by Maurdib View Post
What are hp gains you got from them?
I got right in the neighborhood of 22rwhp over stock, IIRC. That's ARH long tubes and cats over stock manifolds. ARH have a larger tube then the BBKs.
PacMan
mrray13 is offline   Reply With Quote
Old 05-24-2010, 10:06 AM   #27
rd-camaro
rd-camaro's Avatar
Drives: 2010 2LT Blk IOM stripes IO leather
hey found a thread of another member installing BBK LTs...thought everyone would like to check it out...he said he will post videos, pics later today...
http://www.camaro5.com/forums/showthread.php?t=80259
rd-camaro is offline   Reply With Quote
Modifying for " Dummies" Dr Jkel Tuning / Diagnostics -- engine and transmission 209 06-17-2012 11:24 PM
Is anyone else dissapointed by the V6 ENGINE COVER ?? Grandeos Cosmetics and Lighting Modification Discussions 59 11-01-2010 01:13 PM
One of those question's that I would normally think are stupid... Brandons714 5th Gen Camaro SS LS LT General Discussions 122 04-16-2010 03:10 PM
2010 Camaro SS & V6 Line Lock/Roll Control Meister@Torq Suspension / Chassis / Brakes 0 02-23-2010 11:27 AM
LT vs SS; Differences Not Enough DkknightX General Automotive + Other Cars Discussion 52 11-16-2009 07:45 PM
