10-07-2020, 08:52 PM | #1 |
Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
Will 2.75" Corsa Sport muffler restrict an 700whp build?
I'm going to be getting a Mag 2650 SC with 1 7/8" Kooks LT Headers, GESI cats and 3" pipes all the way back to the mufflers, combined with CAI and a tune for around 700whp on 94 octane for my 2018 Camaro ZL1.
I wanted to pair this with Corsa Sport mufflers because my current Borla Atak cat back is already too loud for me and I know the car will only get louder with the high flow cats and it was my favorite sounding muffler I ever owned. My questions is, will the 2.75" size diameter inlet of the Corsa Sport muffler have any serious negative impact on reach the hp I'm looking for? Or will it have only minor implications? I'm thinking only minor but thought I'd ask. This would be for the street only, I have different 3" inlet/outlet mufflers for the track. Thanks
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
10-07-2020, 09:47 PM | #2 |
Drives: 2018 ZL1 Coupe NFG M6 Join Date: May 2017
2” headers is your bigger problem. The Corsa axleback won’t really hurt you, but Corsa is crazy ass loud, so it may not solve your problem.
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School 2017 Colorado Z71 <- Daily 2018 ZL1 M6 <- Not Daily |
10-07-2020, 10:49 PM | #3 |
Drives: 2019 ZL1 Join Date: Mar 2019
That corsa is louder then the Borla. Do you have NPP or non NPP on the borla? Makes a big difference in sound if you have the NPP on the borla.
10-07-2020, 11:14 PM | #4 |
Used to own a ZL1
Drives: '16 Z06 Join Date: Apr 2020
Corsa with headers are loud as shit. You're better off with an NPP system like most Borlas have or that expensive one Corsa is selling now. Either that or getting some resonators.
10-08-2020, 12:22 AM | #5 |
There seems to be some confusion here, Corsa sport mufflers are not as loud as Borla ATAK mufflers. Corsa extreme is roughly the equivalent to the Borla ATAK, while the Corsa sport is roughly the equivalent of the Borla S type.
Furthermore, all NPP systems open all valves wide open at wide open throttle, so the only time an NPP system could be quieter than a CORSA Sport is when the car is not at wide open throttle, and that would only be for the factory NPP system. Both the Corsa NPP and the Borla NPP quiet modes are not very quiet at all, they are more like the Corsa sport and borla S-type until they are wide-open throttle. I’ve owned a Corsa sport muffler before and I currently own the Borla ATAK NPP cat back system that replaced the stock factory NPP system plus i’ve talked to Corsa about their new NPP system.
10-08-2020, 12:25 AM | #6 | |
I’ve never heard any builder or tuner say that 2 inch headers were needed for 700 wheel horsepower. They’ve all said that 1 7/8” is plenty. The Corsa extreme is very loud, but I’ve owned the corsa sport on my now sold 2017 Camaro SS and it’s not nearly as loud as the Borla Atak system I currently have on my 2018 ZL1 Having said all of that, I don’t know how much louder adding long tube headers and high flow GESI cats will make my otherwise stock ZL1
10-08-2020, 07:42 AM | #7 |
Drives: 17 NFG ZL1 17 GTR 22 RS6 Join Date: Apr 2017
The GTHaus exhaust is on the expensive side, but ditches the default NPP for a valve module thats controlled via remote so when you want it quiet it is, and when you want it loud its loud. Ive even recently realized that i can have a in between where i just tap the open button a couple times instead of pressing hold for 3 secs and Ill have in my opinion the perfect sound level. It will def support your HP goals, although Ive been told it wont support over 800, but thats being debated as another user with the same exhaust made 851whp.
Swift |
10-08-2020, 08:08 AM | #8 |
Dyno Show Queen LOL
The 3 inch makes a huge difference over 2.75 ATAK cat back wife's car is perfect can ride with NPP open and make phone calls no problem as long as your not full into throttle my 3 inch ATAk is hard to make calls even in snow mode. If it wasn't for the carbon tips I would put the OEM back on. Both 1 7/8 headers Both supercharged, both Atak's I'm cammed but its a non aggressive stock idle.
power wise I'm at 1004 the headers or cat back isn't holding me back its the fear of the 2 piece thrust bearings and main bearing failures that is.
10-08-2020, 08:29 AM | #9 |
The factory NPP has proven to NOT be restrictive even on builds over 800whp. The cats(Even being GESI) will be the biggest restriction in the exhaust. Any exhaust mods post cats is pretty much for sound only... So your exhaust setup will be fine for 700whp with plenty of room to grow.
2016 NFG 1SS A8
10-08-2020, 12:07 PM | #10 | |
Drives: 2018 Chevrolet Camaro ZL1 Join Date: Jun 2018
The 1 7/8" headers will be plenty for your build. the GESI green cats will be the most restrictive part of the system, but even then, doubtful they are choking out any power at this level. |
10-08-2020, 12:22 PM | #11 |
Drives: 2018 ZL1 1LE Join Date: Apr 2018
See my signature. Youre fine
2018 ZL1 1LE - Summit White
529whp Baseline / 760whp 762tq ARH Ceramic Coated LTH 1 7/8" \ ATI 15% Lower \ RotoFab Big Gulp \ Katech 103mm TB \ Ported Blower \ DSX Fuel System \ Flex Fuel E85 \ Custom Cam \ Dual Springs \ Corsa Exhaust \ Prospeed Heat Exchanger \ Cordes Big3\ C&R Racing Radiator \ LS3 Stat housing \ 160* Thermostat \ NX Lid |
10-08-2020, 09:41 PM | #12 |
Thanks guys, I appreciate the feedback, juicedmotorsports said the same thing too, nothing to worry about.
Cheers
10-08-2020, 09:44 PM | #13 | |
10-08-2020, 10:11 PM | #14 |
I keep the exhaust setting on tour mode, I have headers, green cats, and full borla atak cat back. With the valves shut, its like the stock manifold, cats and the borla atak cat back with valves open when cruising. Its only loud when you are at high rpms, or on the throttle when the valves open. I hear the headers pinging louder then the exhaust when the valves are shut.
However, when your on it past 3500rpm and on throttle it starts to sound like nascar. But i like this setup on street because you can quiet it down when needed. Catless is MUCH louder. |
