09-02-2020, 06:22 AM | #1 |
Drives: 18 ZL1 1LE Join Date: Apr 2013
Upgraded Brake Lines
Planning on tracking my ZLE this fall so I will be changing out to DOT4 fluid so I figured I would upgrade the brake lines while in the process. I know it’s not a necessity, but I figured why not.
I’m not trying to set any track records or anything, but my question is are the Carbon Fiber Brake Lines worth the premium over the Stainless Steel Lines? Thanks |
09-02-2020, 07:45 AM | #2 |
Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
I changed to the CF brake lines. I don't really feel any significant difference between the OEM and the CF. I liked the idea of their high pressure abilities and I was okay at spending that kind of money for piece of mind. But no.....you really don't need them! But the DOT4 is an absolutely must!!!!!
09-02-2020, 09:23 AM | #3 | |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
CF lines are NOT worth the $. Even stainless lines aren't necessary on this car. However if you just gotta do it...(and that's me) the Goodridge or Spiegler lines are very good build quality. I have the Speigler's. https://knsbrakes.com/c/car-items/53...el+Brake+Lines Where in FL are you going? I run at Sebring, Daytona, PBIR and The FIRM often. Are you going to Sebring on the 16th?
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
09-02-2020, 09:29 AM | #4 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
Carbon fiber lines, from what I heard, actually flex more than stainless steel. Yea you might save a couple of ounces in weight, thats about all.
If you want to spend the money and say you have carbon fiber lines, go ahead but stainless steel lines are better overall and cheaper. |
09-02-2020, 09:33 AM | #5 | |
Drives: 2020 Camaro ZL1 1LE Join Date: Jul 2020
09-02-2020, 09:45 AM | #6 | |
I'm certain you can Google carbon fiber brake lines vs stainless steel and find what you're looking for. Actually, I found this: https://www.camaro6.com/forums/showt...=563269&page=2 Get in touch with that member and see what he can tell you. |
09-02-2020, 09:57 AM | #7 | |
Drives: 2020 Camaro ZL-1 1LE Join Date: Jul 2018
Brake lines
Home Track: NCM Motorsports Park
09-02-2020, 09:58 AM | #8 | |
Here's the other thread that goes into a lot of detail on the CF lines and the "why" behind them vs. Stainless, in case the OP is interested: https://www.camaro6.com/forums/showthread.php?t=561322 |
09-02-2020, 10:29 AM | #9 |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
I dove into this subject pretty in depth. You can search for the posts I have on this (there is a thread what a majority of it).
The OEM lines are a higher-grade line than typical rubber lines on your Honda Civic. They are well-enough for most people tracking their cars. With aftermarket lines, really, you are just grabbing that extra 2%. You wont really notice a whole lot on the street or unless you have a sensitive foot/really looking for any change at all. The lower expansion of stainless and CF lines, in general, is minute enough to be overwhelmed by brake pads that compress less than OE. What I am saying is if you change nothing but race brake pads and DOT 4 fluid, you won't really be able to feel the difference that these lower expansion lines provide. Where you will be able to notice a difference, otherwise, would be on-track with brake ON/OFF timing and how that works into modulation. Either stainless or CF lines will last longer than the OEM lines, both to track abuse and purely just over time. The CF lines are stiffer than stainless, but not enough to notice anything between the two. Between stainless and CF, you are just getting lower weight and a better bending radius with CF. |
09-02-2020, 10:30 AM | #10 |
Drives: 17 NFG ZL1 17 GTR 22 RS6 Join Date: Apr 2017
Can agree with previous comments as I jumped on the CF bandwagon when the guy had them made in Italy....I can tell no concernable diff even with SRF brake fluid. I wont say it was a waste of money, ut I would advise anyine else to do as I did. Hell I vote on a CF bow tie first, (sarcasm)
09-02-2020, 10:43 AM | #11 |
Drives: Chevrolet Camaro, Ford Mustang Join Date: Oct 2019
The OEM lines ARE NOT safe IMO. I would get about 4 laps and the pedal would get soft.
I switched to C/F lines... and ZERO soft pedal. I cannot speak to pro/con vs. Stainless... as I've ran Stainless on my other race cars without issue. The C/F fit and finish are second to none, I'm a big fan of them... and felt overall the price was reasonable. Whether you choose C/F or Stainless, I highly recommend upgrading if you do any sort of tracking. Best regards, Dave
2022 SS 1LE - Vivid Orange - SCCA CAM-C & Optima Ultimate Street Car GT
Katech, MSD, QA1, Hurst, Anderson Composites, ProParts USA Custom Suspension, MFR Engineering, Forgeline Wheels, G-Loc Brakes, Nine Lives Racing, MTX Audio, Penske Rapid Repair |
09-02-2020, 12:25 PM | #12 | |
Drives: The DSSV Twins: ZR2 and ZLE A10 Join Date: Oct 2019
09-02-2020, 12:33 PM | #13 |
i have goodridge lines and motul 660 fluid no issues here
09-02-2020, 12:41 PM | #14 | |
Once I switched to the C/F lines, brake pedal remained firm entire sessions. Best Regards, Dave
