07-02-2020, 01:49 PM | #29 |
Drives: '18 Camaro ZL1 Join Date: Feb 2014
An update on the car, took it to get the alignment and it did the job! I’ll post the screenshots later of these sheets they gave me describing the camber and toe alignments, but it looked pretty off. Car essentially drives like it’s brand new now. Thanks for all the help everybody!
07-02-2020, 02:34 PM | #30 |
Awesome! Please post up your before and after alignment specs.
07-04-2020, 07:13 AM | #31 |
Drives: 2017 ZL1 Camaro Join Date: May 2018
Good to hear the alignment resolved your issue, it's always nice when something simple can be the fix.
One thing to keep in mind for others that find their alignments are off, if tires have begun to show abnormal wear from being driven with a poor alignment they may need to be replaced as well to fully correct the issue. Correcting the alignment will help but if tires have goofy wear the car may still not drive correctly and the damage has been done (to the tires), kind of a cause and effect deal.
2017 Garnet Red ZL1 A10
Other Rides, 97 Trans Am, 72 Chevelle |
07-04-2020, 12:34 PM | #32 |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
Good point - and that's why I typically wait to get an alignment until tire replacement. My car doesn't pull on the freeway so doubt its that far off, tires look good. The "sway" is very minor under full throttle at low speed
