Old 11-24-2018, 11:05 AM   #29
gump
Drives: 2019 CRC 001
Yesterday I made a return trip to the dyno at Tick Performance.
This is the first run with the exhaust and zero calibration changes. Yes, I was shocked too!!
Name:  dyno sheet.jpg
Next we installed the Chevrolet Performance cold air kit (84355716) and race filter (84329125). We then made a pass without changing the calibration. We instantly noticed a loss in HP. The increased air flow had caused the tune to run pretty rich. I guess that's why Chevrolet includes a calibration with this kit....
At this point we decided to look at the calibration. Before we started we drained the "dealer installed" gas. Five gallons of VP C10 were poured in the tank. We then adjusted the tune closer to the original O2 readings. Our HP came back along with a couple more!
Our final modification was the cars first oil change. We changed the filter and added six quarts of Mobil 1 0/20 full synthetic. We fine tuned the calibration a little. In all we made twelve dyno pulls. The results tell the tale of how good this combination of parts really is!
Huge thanks to Jonathan Atkins for sharing his patience and wisdom on what was meant to be a day off. I have known Jonathan almost since he first started Tick Performance and can tell you that he is one COOL DUDE! There are not many people who I will let work on my cars. I am honored to call him my friend.
gump is offline   Reply With Quote
Old 11-24-2018, 12:07 PM   #30
Snowblind
Snowblind's Avatar
Thanks for posting the weights of the parts that were removed.
Since this has already been done, what is the end goal for you ?
Old 11-24-2018, 12:43 PM   #31
gump
No problem. I will continue to update the list as I change stuff out.
Interesting question. I would say that the goal is to show Camaro owners how good the factory parts really are. Hopefully people will find this thread interesting.
Maybe I can help some save a little money on their builds? Too often parts are replaced because some other guy has an "internet record". Which means they must be needed, right?
Old 11-25-2018, 07:39 AM   #32
6spdhyperblue
Drives: 6th gen
Cool what do cars baseline on ticks dyno?
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold)
Old 11-25-2018, 08:17 AM   #33
gump
This one made 396. We laid my graph over the baseline from Ticks Gen 6 A8 car and it was almost identical. Within one on both HP and torque.
Experience says that different dynos (and dyno operators) will give different numbers on the same car. The drag strip will tell the true tail. That said, the only real comparison of two cars is at the same track side-by-side.
Old 11-25-2018, 02:09 PM   #34
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
I run the VP MS 109, that's my VP dealer recommended. My car is Magnuson supercharged and I can run about 25-26 degrees of timing plus I run the AEM meth/water with 2-1000 cc nozzles.
Old 11-25-2018, 05:57 PM   #35
6spdhyperblue
Drives: 6th gen
Ahh I see it on page 2 now. About 15hp with the cai what do you think the c10 gave you? Was the timing increased for the c10 over pump? How does c10 compare to e85?
Old 11-25-2018, 07:14 PM   #36
gump
It's hard to know exactly how much the CAI added. I don't feel it was that much. It is a definite improvement over stock and compliments the exhaust. I know we would not have seen the final number without it.
The fuel helped reduce the amount of spark retard that we saw on the first run and allowed a little more timing. It is 100 octane. This will be in the car all next year for consistency.
The reason that I chose C10 is that it is the spec. fuel for the Chevrolet Performance DR525 crate motor. It is available at most NMCA races.
IMO, running E85 is like running a small shot of nitrous.....
Old 11-25-2018, 10:57 PM   #37
GroundhogSS
GroundhogSS's Avatar
"We changed the filter and added six quarts of Mobil 1 0/20 full synthetic."
Shouldn't that be 10 quarts?
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers
Delivered: 08/15/2016
#TeamBeckyD
Old 11-26-2018, 07:15 AM   #38
gump
For drag racing their can be a windage advantage to running less/lighter oil. It's hard to know exactly how much is in there, because I am sure there was still residual oil in the cooling system. It did keep good oil pressure.
As a side note. I run five quarts of 0/20 in the 6.2 DI motor in my COPO. It has 100's of passes and has run a best of 9.08 @ 146 N/A (3100 lbs).
Old 11-26-2018, 02:38 PM   #39
GroundhogSS
Thank you. Good to know.
Richard
#TeamBeckyD
Old 04-08-2019, 07:56 AM   #40
gump
After a very wet start to the year in North Carolina we were finally able to have our first test session last Thursday!
These runs were made with the completely stock drivetrain.
Name:  time slips.jpg
It is crazy how consistent this car was on the stock tires. I think that if it were deep staged you could do pretty well in local bracket races.
The next test will be with the headers, air box, etc. on the stock chassis.......
Old 07-05-2019, 01:20 PM   #41
gump
I put the car on display yesterday to celebrate the 4th!
Old 07-19-2019, 10:00 AM   #42
gump
Last night we tested the car at Shadyside with the headers, air box, etc. that we dynoed at the end of last year. Has it really been that long?!!
This was with the stock tires. So, the results were pretty much as expected. No traction! Note that the car was almost .10 faster from the 330 to the 660 over the baseline test. We are making power. The next step will be to install the small brake kit, axles, driveshaft, cradle bushings, and slicks.
Name:  Time Slips (1).jpg
