12-25-2017, 06:41 AM | #15 |
Drives: 2015 Camaro SS Join Date: Sep 2011
Was the last dyno sheet same dyno and STD correction factor? Just asking because depending on the weather condition uncorrected, STD and SAE can make a big diffrence in your numbers.
2015 Camaro 2SS Cam/Heads/FBO 498/447 SAE |
12-25-2017, 08:55 AM | #16 | ||
old school chevy rodder
Drives: 2013 2SS/RS Manual,DM exhaust,CRT Join Date: Jul 2012
Well your sheet........ not so good IMO....the correction factor is in STD standard no one uses the correct correction factor is SAE as STD can inflate things, the graph has smoothing not good for showing maybe problematic areas to look closer at in the tune as its being adjusted without smoothing that's for sure hopefully and smoothing due to averaging things out can actually cost you couple HP let alone its being a Dynojet and most likely not a heart breaker like a Mustang dyno...LOL And I cant tell WTF is going on with the AFR..? but its seeming ok?
SO IMO; its kind of like they like to inflate egos a little for $ or they don't know wtf they are doing that well....Sorry they might not even have a weather station attached for the correction factor.... Heres a pic of one my old dynos on my first engine it comes out better in the ink just so you can compare..... and my second engine ... Tommy Wongs was a double degree electrical engineer first before he got into running a speed shop. He does what is accurate with the Mustang and Chevys hardware and software the dealer has and Hp tuning. And he has regular dyno maintenance and calibration with weather station attached to the system on the roof. He does not give smoothed or STD printouts... heres the second not such a good copy ink was low and the sensor did not get kicked on for the O2 for the afr until late in the print.. I scribbled on it comparing average torque/HP and it netted me gains where I wanted it in the torque and where I drive with a milder cam from stroking it, some day I will go big again yet its all about the $ and dyno tunes I know don't come cheap from him...$550 range and a waiting list months out sometimes especially for engine work.. SO IMO your low, the thing is just for comparisons but with your mods what you put down to the rear wheels could be much different than what one dyno says unfortunately not all dynos or especially operators are created equal. But it is a place to start for mods, and hopefully they don't charge you too much..... STD was a correction factor just using Detroit Michigan numbers I of its temp at like 60 and elevation and etc and usually comes out about 4-5% more than SAE society of automotive engineers from what I know. Let alone load bearing versus non load bearing.....dynos are all different; and the difference between them and what they are trying to achieve with the calibration of the dyno if its more mustang heart breaker load bearing calibration or .... calibrated to what ever...LOL Basically reading up on dynos has in a way been enlightening and annoying LOL but its all in what you know and what they have that one measurement device set too.... its not like the things are all set the same..... but maybe these can tell you a little. Merry Christmas, and whats in a dyno number....? a whole lot of calculating HP off of torque what moves you.......... You see on my dynos that the second engine a stroker with a much milder cam I went for torque which I got from 3000 to 5000 area in a plateau of power and it starts off about 50 ft lb more from the get go and the average Hp and Torque increase all across the board but the loss of a top end number for HP is due to cam design as I did have a .639/.623 lift 235/239 112 lsa TSP cam and went down to a 114+4 LSA .613/.578 with like 224/235 from Cammotion for ease on the valve train until I can afford a cash infusion to ls7 small bore heads , intake new ls7 headers , 102 etc.....
12-25-2017, 10:01 PM | #17 |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
The first dyno tune was done on a dinomite dyno and I never got a printout. Im not sure about std and sae.
01-04-2018, 01:59 PM | #18 | |
01-04-2018, 04:55 PM | #19 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
yep, thats a dynosheet for sure! lol
on a semi-serious note: are you going to dyno again after LT's and a tune update?
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
01-04-2018, 05:43 PM | #20 |
01-05-2018, 12:38 PM | #21 |
GPI Sales Consultant
Feeling better than a few months ago?
GPI Max Package 2.0: Brodix BR7 heads/GPI porting, MAX3 cam, ST2116LSR, BSR Max Lift rockers, LS7 LSXR with 103mm TB, Vararam OTR, Mcleod RXT, G-Force/Strange 9" IRS setup with 4.63 gear. 551whp, 11.1@124mph.
Got a question about a GPI product? Feel free to shoot me a message! |
01-05-2018, 01:20 PM | #22 |
Yes.....cant wait for the longtubes and a improved trans tune to see how it runs at the track. I picked up almost 3 mph up top with just from him improving the tune. He didnt do the improved trans tune because it wss raining that day. I need to hold off my buddies 5.0 lol.
01-05-2018, 02:32 PM | #23 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
Looks good to me, what is your mods list these days?
I did 367rwhp with: 1.75 Kooks, cats Stock exhaust CAI air box Tune PTB + rod mod intake, 3200 converter, 17x7 fronts, 18x10.5 NT05R rears, went 12.06 with traction issues. Plus 3.91 went 11.84 1.59. I can tell you what I'd change to go 11.7's.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
01-05-2018, 03:52 PM | #24 | |
01-05-2018, 08:32 PM | #25 | |
You're not gonna catch the Coyote on the back half, you've gotta do all your work on the first half and make him try to run you down. What did you get your trap speed up to? I recall it was pretty terrible, and attributed to the tune.
01-05-2018, 08:45 PM | #26 | |
01-05-2018, 09:06 PM | #27 |
Drives: 2010 Camaro 2SS Victory Red 6M Join Date: Apr 2015
You really shoulda went 2" on those headers. They make the most power everywhere vs any other. That stall you have is helping you out vs stock, but you really should be using a 4k stall running n/a. Get those issues addressed and traction will be your next problem.Be glad you aren't a TR6060 car...........talk about traction issues!!!
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19 Gone on 12/28/19 R I P 2010 2SS 6M Victory Red/Black (old ride) CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back. 12.6 @ 115 SAR as of 9/19/15 Gone but never forgotten. |
01-05-2018, 09:10 PM | #28 | |
