09-10-2017, 10:23 PM | #1 |
Drives: 2017 Camaro 2SS Join Date: Aug 2017
Hub adaptors
In the market for new wheels. Curious about hub adaptors. Some of the wheels are hub centric some are in the 70 mm bore range. Wondering if the wheels not being hub centric would be bad news in the long run with or without an adaptor?
09-11-2017, 05:19 AM | #2 |
SABIO
You mean Hub Ring.
Hub Rings let you use slightly larger bore centers. It is recommended to use them. They are cheap. Usually aluminium sometimes plastic. A Hub Adapter allows you to use different bolt patterns
09-13-2017, 04:58 PM | #3 |
Drives: SUMMIT WHITE 2016 1SS NPP 6MT MRC Join Date: Jan 2016
You will get a wicked vibration if they don't match. Definitely run them, they are sub $10 for a set.
