![]() Drives: 2016 1LT Red Join Date: Aug 2022
2016 Camaro 1LT Radio
hey guys, not sure if there is any info on here, but figured I would see and ask.
so my question is this, I have a 7-inch Mylink system, non-bose, and also the amp is not in the trunk. so here is my question, I want to find the remote wire on the factory radio to use on my Hertz H8 DSP. now this unit needs a Remote IN and I already know what every other wire is on the Hertz h8 DSP. please help out and inform me as I wanna keep the factory head unit. i also know that there is not one company that really makes an after-market harness for my type of car and year. |
#2 | |
![]() ![]() ![]() Drives: Chevrolet SS 1LE Join Date: Oct 2019
I don't think you're going to find a "Remote" turn-on signal from the factory radio module. That really applies to aftermarket head units that have line level speaker outputs and a separate turn-on signal output on a blue wire. Most modern interfaces have a way to sense music signal on a speaker-level from a factory module, and briefly scanning the instructions for your Hertz, in section 5.3 it says you can turn it on:
Matt Miller
2020 SS 1LE |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
There are threads on here showing how to get into the unit to the right of the glove box. I did a DIY on my 2016 1LT with pictures. Search threads started by me.
Official Detailer of CamaroFest 8 & 9, Examples of my detailing work: https://www.camaro6.com/forums/showt...=521655&page=3
https://www.camaro6.com/forums/showt...=547470&page=2 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. |
#4 | |
thanks very helpful, I did however notice that as well. but was hoping maybe other people have other ideas
I did, however, ran 2 sets of wires to each of the speakers, this was done to install all newer speakers for this install. there are 2 amps and the DSP. Quote:
I've attached the pages from the Factory Service Manual showing every terminal on every connector to the factory radio module. I don't think you're going to find the turn-on signal you're looking for, but look at over and see. I think your DSP unit is intended to sense incoming speaker-level signals and turn on automatically when the radio unit starts sending signals over its audio outputs.
I also attached the FSM instructions for accessing the radio module. It's really not hard, but you have to work underneath the passenger-side dash. On my 2020, I did not even have to drop the module out to get to the connectors I needed, but YMMV depending on what you want to do (and your 2016 will have different style connectors than mine).
Matt Miller
2020 SS 1LE |
#7 |
Electrical Engineer
From the A11 document, you can see that pages 10 and 11 have harness X2 in which Pin 3 is "Radio On Signal". You'll need to take a probe to that pin to see what it does and if it acts like a useful remote signal. Be sure to put a 0.5A fuse on that wire if you tap it and run it back to the DSP. I wouldn't add amp turn-on signals to it without an isolating relay with diode protection.
2023 1SS A10 Black NPP/C2U/H72
Historically an Accord and Camry owner with self-performed maintenance/repair. Electrical Engineer and Acoustics Engineer. 1100: 5/3/22 . . . . . . .2000: 6/25/22 3000: 6/29/22 . . . . . .TPW : 8/15/22 3800: 8/16/22 . . . . . .4000: 8/17/22 ETA : 9/13/22. . . . . . .5000: 9/8/22 6000: 9/10/22 |
#8 | |
https://www.camaro6.com/forums/showthread.php?t=547568
#9 | |
Thank you so much, this was very helpful, now the DSP I’m installing and wanting to use is, Hertz H8DSP.
If you have a moment please have a look at the manual and help me with a pointer please. Quote:
#10 | |
Thank this is awesome, good to know where it is. In my 2016 LT1
#11 |
Go back and re-read Post #2: that's exactly what I did there.
Matt Miller
2020 SS 1LE |
Thread Tools | |
