![]() Drives: 2017 Camaro Join Date: Feb 2020
Ac issue...
My 2017 camaro. Every now amd then the ac won't cool. When I disconnect the negative terminal for about 5 minutes it works fine.
Why is this happening? When it happens it won't cool amd after I turn the car off the fan on the engine stays on for a longtime.
Anyone ever dealt with this? thx
I'd check the thermostat, the A/C could be turned off and the engine fan running for a long time after key off because the ECM thinks the engine is overheating.
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
No codes?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 2SS, 50th pkg, M6, MRC, NPP Join Date: Jan 2016
Need more information.
When the A/C works, does it work fine? Adequate cooling when the vehicle is moving as well as when it is stopped? Duct temps always cold on both passenger and driver side? What is coolant temperature gauge doing while driving or at standstill? Could be problems in two systems: engine cooling and A/C. |
No codes. No check engine.
When the AC works it works great when stopped or moving. gauge is normal. not moving.
#7 | |
What is your coolant temperature reading? |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
On mine, it was the thermostat. Replacing the thermostat is one of the easiest DIYs on this car. I got an ACDelco at Autozone for $75 but I have a commercial account. Expect to pay $100.
Official Detailer of CamaroFest 8 & 9, Examples of my detailing work: https://www.camaro6.com/forums/showt...=521655&page=3
https://www.camaro6.com/forums/showt...=547470&page=2 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. |
#9 |
K great. Temp seems normal. I will change it out.
But would a thermostat cause the ac not to throw cold air?
#10 |
![]() Drives: 2016 1LT 'Vert Join Date: Feb 2022
Generally, Yes. A bad thermostat will eventually result in A/C shutting off. Because the condenser is forward of the radiator, the a/c will eventially turn off at a prescribed coolant temperature to reduce load both on the engine and cooling system.
The air exiting the condenser is warmer and it takes several HP to spin the compressor. |
#11 | |
This post shows exactly where mine stays put: https://www.camaro6.com/forums/showp...4&postcount=11 |
#12 |
![]() Drives: 2016 SS Join Date: Jan 2016
your thermostat is bad, just replace it.
#13 |
![]() Drives: Chevrolet Blazer Join Date: Oct 2021
IDK about the Camaro but years ago I had a similar situation on a Buick. Replaced the thermostat to no avail. Finally resolved the issue replacing a relay that controlled the AC. That was on a 1980s vehicle, therefore it may not apply here.
2023 2SS 1LE Radiant Red
Deposit - 02/04/2022 Order Submitted - 05/05/2022 1100 - 05/26/2022 3000 - 11/22/2022 3800 - 12/16/2022 4000 - 12/30/2022 4200 - 01/05/2023 ETA - 02/05/2023 |
#14 |
![]() ![]() Drives: 2016 Camaro 2SS Join Date: Apr 2018
Yeah if your temps are normal it's not your thermostat. The actual temp sensors inside the car are prone to failing and it sounds like what is happening to yours was what was happening to mine before I had my dealership replace them a few years ago.
Thread Tools | |
