Old 08-13-2022, 12:33 AM   #1
Need4Camaro
Drives: '17 Camaro 2SS & '99 Camaro Z28
Radiator fans won’t turn off even when car isnt running after Rotofab Intake install
My radiator fans are always running even when I turn the car off! I can’t get them to go off. I left the sound tube disconnected for now until I get a block off plate, but would that cause the radiator fans to run indefinitely even when the car isn’t running?
Need4Camaro is offline   Reply With Quote
Old 08-13-2022, 02:03 AM   #2
Yang N’ Bang
17’ Hyper Blue 2SS
Yang N’ Bang's Avatar
Drives: 17’ Camaro 2SS
Check your temp gauge when the car’s running, if it stays flatlined you might have a bad sensor, that’s the issue I had anyway.
Yang N’ Bang is offline   Reply With Quote
Old 08-13-2022, 07:18 AM   #3
STEVE41
Drives: 2016 SS
you have a bad thermostat.
STEVE41 is offline   Reply With Quote
Old 08-13-2022, 08:01 AM   #4
s346k
s346k's Avatar
Drives: 18 1SS 1LE
did you disconnect the maf? mine does that every time the maf gets unplugged. i typically start the car and shut it off again and they quit.
Old 08-13-2022, 08:25 AM   #5
Need4Camaro
Yeah I had to unplug the MAF to do the install. I took it out again and the fans stopped. That’s friggen weird.
Old 08-13-2022, 10:15 AM   #6
SS_Don
SS_Don's Avatar
Drives: '22 Camaro 2SS
Try removing the neg battery terminal for a few minutes. I removed mine before I did my CAI install and had no issues.
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes
Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo | ZL1addons Deluxe Rock Guards and Stealth Lift Pads | Escort MAXcam360c
SS_Don is offline   Reply With Quote
Old 08-13-2022, 10:36 AM   #7
KirkH
I had same thing. Replaced thermostat. Fixed.
Official Detailer of CamaroFest 8 & 9, Examples of my detailing work: https://www.camaro6.com/forums/showt...=521655&page=3
https://www.camaro6.com/forums/showt...=547470&page=2
https://www.camaro6.com/forums/showthread.php?t=527474
No one on Earth has detailed more Camaros.
Old 08-13-2022, 10:46 AM   #8
ctrlz
Yep. That could even be a bug in the ECM coding.
Copyright ©2000 - 2023, vBulletin Solutions, Inc.
