07-07-2023, 07:39 AM | #1 |
Camaro #4
Drives: 2017-Hyper Blue Metallic-2LTmanual Join Date: Dec 2015
Driver's door trunk release not working FIXED - OPERATOR ERROR
So where do I start looking for an issue? It worked fine before the battery/alternator crapped out, but when I tried to use it the other day - nothing. I had to use the trunk release on the remote.
Any ideas?
Don M
Supercharged LGX + 6 speed manual = FUN!! Last edited by DonM; 07-09-2023 at 12:17 AM. |
07-07-2023, 08:01 AM | #2 |
Sporting Foole
Drives: 2010 Camaro SS Join Date: Sep 2019
Mine sometimes takes a few punches before the trunk unlatches. I figure a funky contact in the switch but haven’t done any investigation yet.
07-07-2023, 08:05 AM | #3 |
Camaro #4
I'm not TOO worried about it at the moment ... at least not until my remote falls apart like the last one
Don M
Supercharged LGX + 6 speed manual = FUN!! |
07-07-2023, 11:49 AM | #4 |
I have to do the same here as you. Not a problem as of yet.
07-07-2023, 01:18 PM | #5 |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
A small squirt of regular old WD40 will fix that button. After applying WD40, work the button about 20 times. Cleans of the contacts and frees up contacts.
07-08-2023, 03:02 PM | #6 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
Switch was bad on mine. I just pulled the panel and replaced it.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
07-08-2023, 07:49 PM | #7 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
Switch bad on mine too..plucked it out without removing door panel…tight fit ..switch is separate from bezel
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
07-09-2023, 12:18 AM | #8 |
Camaro #4
It's working now. Either *I* forgot to FULLY depress the button - OR - I forgot to hold it in for a quick second.
Don M
07-09-2023, 07:39 AM | #9 |
Drives: 2024Camaro 2SS CE Convertible Join Date: Jul 2013
07-09-2023, 09:34 AM | #10 | |
Drives: 2010 2LT/RS Join Date: Mar 2015
I tried pulling out my switch with a plastic trim removal tool and for the life of me cannot remove it. Looks like the door panel has to come off on my end. How did you do it?
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can. |
07-10-2023, 06:35 AM | #11 |
YouTube-Car Nation Videos
Drives: 2010 Chevrolet Camaro Join Date: Nov 2019
Get a new car battery and thank me later for saving you tons of time.
