10-03-2022, 10:10 AM | #1 |
Drives: 2011 Chevy Camaro 2SS A/T Join Date: Feb 2020
Cooling hoses part number
Hello, any chance of finding pre-made hoses with connectors that go in/out of the thermostat?
Could you please advise any link or part numbers? There are two hoses input / output of the thermostat. Each of these is divided into 2 parts by means of a connector. On rockauto I can only find hoses that I need to cut by myself, and without connectors. V8 engine |
10-03-2022, 10:19 AM | #2 |
Drives: 2010 Camaro SS 6m Join Date: May 2020
Need more information. Are you referring to the hoses that go to the heater core? What connectors are you talking about? Are you trying to reroute the hoses so they don't lay on top of the intake manifold?
10-03-2022, 10:24 AM | #3 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
I just went to the parts store and bought straight hose and cut it to length. That's essentially what the Katech hose relocation kit does. This allowed me to tuck it behind the passenger side heat shield and get it out of the way.
10-03-2022, 10:52 AM | #4 | |
I would like to use factory OEM hoses (if they are) rather than using the ones sold by length (it's the last step). |
10-03-2022, 10:54 AM | #5 |
Could you please see the attached images above ? I marked with red the hoses and connectors on attached photos. Do I have any chance to find the OEM part numbers of these hoses assemblies ?
10-03-2022, 01:46 PM | #6 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
Do your hoses route under the engine cover or go through the heat shield beside the exhaust manifold?
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
10-03-2022, 03:47 PM | #7 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
If it's a 2011, they should run on top of the intake, but lots of guys (me included) switch to the 2012 and later hose with the aluminum section that runs down by the manifold.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
10-03-2022, 03:53 PM | #8 |
Yeah that's what I thought. Is it a real pain to switch it over?
10-03-2022, 09:34 PM | #9 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
I relocated mine with Gates hoses. You'll want to carefully cut the hoses, especially at the heater core. It appears GM used a sealant on the connections. Twisting too much could damage the heater core. I tried to twist them off because I wanted to save them. I gave up and cut them.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
10-03-2022, 09:44 PM | #10 |
Started#gottalovethatblue
10-03-2022, 09:47 PM | #11 | |
https://www.rockauto.com/en/tools/ho...s,coolant+hose |
10-03-2022, 09:50 PM | #12 | |
10-04-2022, 06:31 AM | #13 |
These came with a GM part number on mine. I think they're the ones for all '12+ Camaros. These guys are just selling them as an upgrade because of people like you and me who want to get the heat off of their intake manifolds.
10-04-2022, 07:36 AM | #14 |
^^^^ This
GM part number on Rock Auto is GM GENUINE 22962570. I found them under the 2012 ZL1 section. It's a PITA to get the heater core end off and back on, but worth it IMO.
