dave@hennessey
Old 09-13-2022, 06:14 PM   #1
fidel_1ss
Drives: 2015 1SS Camaro
REAR END CLUNK/RATTLE
I purchased a 2015 1SS M6 a couple months ago, completely stock and well taken care of. Soon as I had time I installed new shocks all around with lowering springs. Eibach parts for all of it. About a week later i started getting a clunking noise coming from the back whenever going over small or medium bumps. Or when i pulled into my driveway which is about 1/2” difference from the road. I pulled my rear seats down and it gets louder. I’ve checked every single nut and bolt in my rear suspension.
Starting last week I started getting a vibration in any gear going 75 or over. It only happens when I start accelerating as the car starts shaking but it only happens sometimes. Earlier today I did a pull and flew past 75 with ease. I let go of the gas for about 6 seconds and once i applied it some, the vibrations started. I’m extremely frustrated as it takes the joy out of driving it knowing those noises are there.
fidel_1ss is offline   Reply With Quote
Old 09-13-2022, 07:24 PM   #2
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
Any play in the carrier bearing on drive shaft?
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 09-13-2022, 08:36 PM   #3
fidel_1ss
i have not checked the carrier bearing. i haven’t seen that as being a cause. but i’ll look into that as soon as i can
Old 09-14-2022, 12:54 PM   #4
HyperV117
HyperV117's Avatar
Drives: 2010 Camaro 1SS
With the vibrations I would make sure you torqued those wheels back correctly. I doubt anything is going on the drive shaft at this point. As far as the clunking chances are the car settled on those new springs and you are hearing the top rings touching. They sell rubber isolators that make it better.
HyperV117 is offline   Reply With Quote
Old 09-14-2022, 08:06 PM   #5
fidel_1ss
wheels are torque to spec. the springs came with isolators on them so that’s not my issue. i can describe the clunking as if the door wasn’t closed all the way so it just bangs around on the latch. that’s my best description
Old 09-15-2022, 07:03 AM   #6
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
Doesn't sound like those springs are setting good and solid. ....so you only hear it when you go over a bump or something and has to engage those shocks/springs..... hmmmmm. Or could be a cradle/control arm bushing arm is split to give the vibration. So you could potential have two issues.
Before I installed my coilovers, I would hear that type of noise from my back left spring (lowering springs) on occasion, but did not have any vibration.
hrpiii is offline   Reply With Quote
Old 09-15-2022, 08:42 AM   #7
fidel_1ss
yes the sound didn’t start until after the springs were installed. it’s coming from the right side of the car. i can only hear it when the right side hits a bump or when i pull out of my driveway and the right rear tire hits the road
Old 09-15-2022, 08:59 AM   #8
SIM GhostrdrZ
SIM GhostrdrZ's Avatar
Drives: ‘14 Z/28 ‘14 ZL1 M6 vert
I had a bad cradle mount bushing in my zl1. Put solids in and it went away. Couldn’t tell bushing was bad until I lifted and put pressure on it. Then I could see the forward left and right acted differently to similar movements. But so many different bushings/arms in the rear you’ve gotta lift it and investigate.
SIM GhostrdrZ is offline   Reply With Quote
Old 09-15-2022, 03:28 PM   #9
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
Going out on a limb here but do you think that one of your axles just craped out due to the drop?
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 09-15-2022, 07:37 PM   #10
fidel_1ss
springs have been on for about 6 months now. i haven’t had an issue with anything major. i just did my two rear wheel bearings a couple weeks ago. the vibration started around the same time
Old 09-16-2022, 12:30 AM   #11
morepowerjoe
How much of a drop did you get and how many miles are on your current axles?
Old 09-16-2022, 07:10 AM   #12
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Check all suspension hardware, especially the har d to get to ones. I had almost same issue. It was a bolt that backed out. Otherwise I would look into those springs you put in.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 09-16-2022, 08:35 AM   #13
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Just another shot in the dark, but when we installed my Pfadt springs in my Camaro, the instructions showed and stated that on the top portion of the springs where the coils end is supposed to face the "center" of the car. I'm guessing so that they sit correctly in the upper isolators, if the camaro has them?? That could cause some minor movement if they are not seated correctly. I know my mustang I had there were isolators in the upper suspension where the springs sat.
1JEWLDSSRS is offline   Reply With Quote
Old 09-16-2022, 09:26 AM   #14
fidel_1ss
I did a 1.4 rear and a 1.1 in the front. if they haven’t been changed, then they’re stock. so about 80k miles. i bought the car with 65k on it
