08-24-2022, 04:27 PM | #1 | |
...not a marine biologist
Drives: 2012 Camaro RY SS LS3 Join Date: Mar 2013
Turbo Flyby Video with boost
Been a while since I posted anything. Here is a new video doing some side by side pulls being filmed so you can hear the boost kick in with a hood exit. If you like turbo spool, this is for you. I always wanted to know what I sounded like passing people!
Forged 6.8L BTR 416 Stroker kit with K1 crank and Wiseco pistons (10.5:1) Huron Speed single turbo kit for 5th Gen with Turbonetics 78mm/1.15 ar, oil cooled BB turbo Intercooler Deatchwerks 90# Injectors & ADM FPCM and ZL1 Fuel pump 3 bar map sensor 8psi boost & ported TB Chromoly rods & LS7 lifters BTR dual valve spring kit 230/234 114 LSA .621/.603 Cam Motion cam 25% Powerbond UDP Might Mouse CC ARP head & cam bolts(not studs) Twin disk Monster clutch ZL1 rear end, zl axles, zl1 driveshaft and zl1 cradle with Royal Purple Unknown HP - Remote street tuned by Vengeance
Forged 416 stroker Turbocharged with Huron Speed with Cam Motion custom grind,Tuned by Vengeance, 8psi, 25% PowerBond UDP, Ported TB, shaved heads, LS9 gaskets, chromoly pushrods, BT trunnions & dual valve springs, IWIS, Might Mouse CC, SJM Line Lock,, MSD 2-Step, ZL1 Rear End, ZL1 spoiler, Strut Brace, ARP bolts, Skip shift elim, A-Pillar Gauges, FR Style 41 20X10, 3 inch exhaust, blackouts, Lowered, Custom badges, Hines vents,RPI fender vents, Technostalgia Tail Lights, Metra Kit, Pioneer stereo, Morimoto RGB Halos,
"The Great Awakening" on gab.com |
08-26-2022, 07:57 AM | #2 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
Wow. Give yourself a pat on the back.. That is an animal
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
08-26-2022, 02:22 PM | #3 |
Wife named it "Ghost"
Drives: 2012 Camaro Summit White 2SS/RS M6 Join Date: Jan 2017
That sounds beyond awesome. Could listen to that all day!
2012 2SS/RS Camaro M6 Summit White
08-27-2022, 09:20 AM | #4 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
I like your build, needs a rain flap |
08-27-2022, 11:49 AM | #5 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Looks fun! Clean looking hotrod
09-06-2022, 08:41 PM | #6 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
Tags |
flyby video, huron speed, monster clutch, turbo, turbonetics |
