Old 06-09-2019, 01:23 PM   #1
19SW1LE
Drives: 2018 LT 1LE
1SS 1LE questions
Hello, new owner of a 1SS 1LE. I've been trying to learn all the features of the car and the owner manual as thick as it is, does not explain many features of the car.
Does it suppose to have a g-meter, HUD, and a diff temp readout? TIA for the help.
19SW1LE is offline   Reply With Quote
Old 06-09-2019, 01:59 PM   #2
DenverTaco07
DenverTaco07's Avatar
you need to be in performance view on the display to see g meter, tire temps, diff temp, 0 to 60 timer, etc.
yes, you shoud have HUD, the controls are on the dash left of steering wheel.
Old 06-09-2019, 02:25 PM   #3
19SW1LE
Drives: 2018 LT 1LE
Thanks. Found them, I had to add pages under settings. HUD was hiding out of alignment. Did not see diff temp though, only e lsd slip.
Old 06-09-2019, 05:52 PM   #4
SpazmXylam
Because Racecar!
SpazmXylam's Avatar
Drives: 17 SS 1LE
Don't think diff temp is a thing. Trans temp is though. Trans and Diff share a cooling circuit so i'd imagine the temps between the two should be similar.
SpazmXylam is offline   Reply With Quote
Old 06-09-2019, 08:03 PM   #5
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
G-meter in HUD and in cluster display. When the dash display is selected the HUD holds the peak momentarily so you can see it rather than just the normal live display.
No diff temp.
Just coolant temp, oil temp, trans temp.
Though, like posted, you can expect the trans and diff to be about the same, as they share the same cooler circuit.
The eLSD display shows the percentages of rear wheel slip on the bottom and LSD lock up on top.
'18 1SS 1LE Black, PDR
Old 06-09-2019, 09:01 PM   #6
DenverTaco07
right....trans temp
Old 06-10-2019, 08:51 AM   #7
19SW1LE
Drives: 2018 LT 1LE
Got it, thanks for all the replies.
