11-13-2022, 03:50 PM | #15 |
Old Gearhead
Drives: 2023 GMC Sierra Denali Ultimate Join Date: Nov 2018
It took me maybe 15-20 minutes hooking the Battery Tender harness to the battery. I'm using a Battery Tender Plus that I've used on a number of cars.
2023 Camaro ZL1 convertible - black - SOLD
2023 GMC Sierra Denali Ultimate - black |
11-13-2022, 04:02 PM | #16 | |
Good job! I looked up your model and was about to ask if the fuse was blown. Also, that’s why I asked what you were using. Sometimes it’s the little things that we don’t notice that end up being the problem.
11-13-2022, 09:15 PM | #17 |
Drives: 2024 Silverado 2500, 2018 Trax Join Date: May 2017
I noticed a vampire battery drain on mine. A full charge and tender seems to improve things. My brother in law has to use a tender on his Porsche 911 too.
Mine runs under the hood. No battery issues on my Silverado 6.6 Duramax. |
11-13-2022, 09:26 PM | #18 | |
Drives: Chevrolet Camaro LT1 Join Date: Sep 2022
Jim G |
11-14-2022, 02:38 AM | #19 |
Drives: Chevy Camaro Join Date: Apr 2020
Get rid of those stupid clamps and bolt it directly to the battery. When you want to drive the car you can un plug it from the wall and toss the whole thing in the trunk. Shutting the cars computers off will also lessen the voltage draw.
11-14-2022, 08:36 AM | #20 |
Hot Camaro
The one thing that I do differently from you is how I clamp the positive side. Instead of using the larger mouth of that clamp, I slide it further along to use the part that's very near the hinge of the clamp and I get a solid connection.
11-14-2022, 08:46 AM | #21 | |
I find that clamping VERTICALLY onto the post works much better. That puts the clamp on in a way that eliminates the tendency to want to slide, and the jaws of the clamp tend to "bite" into the terminal, especially if you jiggle the clamp back and forth a bit before releasing hand pressure on it. The clamp then stays in place and the electrical contact is good. On the specific post sizes on the Camaro, and the very small clamp size of my Battery tender's clamps, I did not have to take a lot of care however. The clamps are small enough that they grip even the tiny positive post well. Jim G |
11-14-2022, 08:50 AM | #22 | |
Hot Camaro
11-14-2022, 09:55 AM | #23 | |
Does anyone know how long our Camaros can sit undriven before the battery has discharged enough to warrant a top-up charge? I want to ensure I don't let it get TOO weak, which could hurt the battery or some of the onboard settings or systems. Jim G |
11-14-2022, 10:02 AM | #24 | |
Hot Camaro
11-14-2022, 10:14 AM | #25 | |
A rechargeable jump starter is typically a standalone device about 3" wide x 1" deep x 10" long approximately. You precharge it by conencting to a 120 volt wall socket. You then take it to the car which can be ANYWHERE, attach its (included) harness to your battery terminals, and start the car instantly. Even a big V-8. Even a big DIESEL. Then you can run the car for a "nice day" drive, get it fully warmed up and the battery fully charged, and re-park it. But you might not even have to start the engine. i THINK if you simply connect the jump starter to the car's terminals, I think it MIGHT charge the battery? I don't know that for sure, but maybe someone else reading this thread does know. Jim G |
11-14-2022, 10:21 AM | #26 | |
Hot Camaro
Once stored for the winter, it doesn't come back out until spring because of road salt and other chemicals. That makes it impossible for the "day drive" sort of thing you're mentioning. I have taken rechargeable UPS devices (Uninterruptable Power Supply) to the storage unit and plugged in my small tender to see how much charge boost I could add that way. It was not significant and ultimately didn't really help. I have a solar-powered Battery Tender that I intend to ask my storage company about hanging on the outside of the overhead door this winter as it may be a viable option to keep the battery charged up over the cold months. |
11-14-2022, 10:24 AM | #27 | |
Jim G |
11-14-2022, 12:55 PM | #28 |
Hot Camaro
There's always risk like that. I would hope that the risk for this facility would be low given location and the security controls they have in place (code-controlled gate for off-hours access when office is closed, no overnight access through gate due to time limits for access, well-lit area overall, security cameras).
