09-18-2021, 09:44 AM | #15 |
Best mod on gen5 engines is a flex sensor and tune if you have E85 available in your area. Should be able to run close to full pump E on a stock car...as you do mods you will have to mix the E content down which doesn't cost much for power just adds the hassle of mixing. Long as you can run E40+ the benefits of E will out weigh the hassle of mixing. 50/50 mix of pump E85 and pump 93 will land around E52. The flex tune will make all the changes to the tune so all you have to do is fill it and monitor the E content to make sure the system doesn't have too much E in it.
Look at it like this...A cai, headers, tb, and 93 tune car will make the similar power(620-630whp) as running full pump E on a otherwise stock car. If you do flex fuel, headers, cai, ported tb, you will probably need to mix the 50/50 as I mentioned above. The car will make more power consistently on E being it will be able to maintain full timing at higher Manifold temps and overall much more resistant to knock vs 93.
2016 NFG 1SS A8
09-18-2021, 01:53 PM | #16 |
Drives: 2019 Chevy Camaro ZL1 Join Date: Sep 2021
Hows traction? I wanna be able to ride on some good performance tires year round, dont wanna have to use slicks, Also what range do you think power becomes too much/unuseful for some regular pilot 4S or pirelli p zeros?
09-18-2021, 01:58 PM | #17 | |
09-18-2021, 02:20 PM | #18 | |
Drives: HBM ZLE Join Date: Aug 2017
Boost is pressure the supercharger is pushing into the engine. Different size supercharger pulleys or balancer pulleys will change the boost going into the engine. Raising boost will result in more hp but creates more heat, especially with the smaller stock blower. Because of this, the extra hp won't last long and result in more engine heat soak, which will lower power for the following pulls. Lowering boost will have the opposite effect, lower power but more consistent pulls. This is my understanding anyways |
09-18-2021, 03:19 PM | #19 |
I drive mine year round on 4S when temps are above 40F. Traction can be a problem below 60 mph at WOT, but you quickly learn what you can and can't do.
'20 ZL1 1LE A10,
09-19-2021, 08:48 AM | #20 | |
09-19-2021, 01:31 PM | #21 |
09-19-2021, 02:12 PM | #22 |
My Kong Stage X is in process so I'll soon see what difference their super-duper version makes in performance.
'20 ZL1 1LE A10,
09-19-2021, 04:26 PM | #23 |
Yes will definitely be interesting to see the power difference between their regular port job and the x version. Pretty much finished up tuning, definitely can't run 37% E, high side drops as I have no cam. Thinking 30% E is gonna be the sweet spot with my build pushing about 13lbs of boost. These pulls were in ideal conditions, about 47* outside, great DA
09-19-2021, 04:59 PM | #24 | |
'20 ZL1 1LE A10,
09-19-2021, 06:19 PM | #25 |
As long as your cam has the bigger fuel pump lobe, and with your added low side support, you should be able to run a good amount of ethanol i would think. Only thing holding me back is high side which would be a cam upgrade. Maybe down the road but not anytime soon, time to dump more money into our house haha
09-19-2021, 09:33 PM | #26 | |
Drives: 2019 ZL1 Join Date: Mar 2019
Won't happen. Will need bigger injectors/pump and/or port injection.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
09-19-2021, 10:11 PM | #27 |
The former. Which fuel pump are you running?
'20 ZL1 1LE A10,
09-20-2021, 04:57 AM | #28 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
Tags |
zl1 1le pulley, zl1 exhaust, zl1 mods |
