Old 09-17-2021, 10:03 AM   #1
MartinLe
MartinLe's Avatar
Drives: 2017 Chevrolet Camaro ZL1 M6
HOW DID YOU SIPHON THE GAS OUT OF YOUR TANK
Hey Guys,
I have a full tank of fuel and have to replace the low side fuel pump. I tried to snake a 1/4" vinyl hose down the filler tube - didn't work. I tried a 3/8" black fuel line and couldn't get it down the tube. Am I missing something here, or do I have to lower the tank a little and take it from the top or maybe loosen the filler connection and go in there?
Thanks
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper
FIC+30%
DSX Flex fuel/Low side
NW 103mm TB/Roto-Fab CAI
Monster S Series
Elite E2-X
2" TSP LT's
BMR:BK063, BK060,TCA061, UTCA060, UTCA063
Weld Beadlocks/17" NT5R2
MartinLe is offline   Reply With Quote
Old 09-17-2021, 10:16 AM   #2
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Try placing the plastic funnel that comes with the car (in trunk) into gas fill tube to open the anti-siphon valve and then insert a small diameter hose through it?
Old 09-17-2021, 10:20 AM   #3
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
This. You have to use the funnel to open that valve or its a no go.
476 rwhp/440 rwtq (sold)
Old 09-17-2021, 10:25 AM   #4
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Originally Posted by MartinLe View Post
Hey Guys,
Thanks
You can disconnect the fuel line, then command the lpfp on using hp tuners to pump the gas out. (Unless the pump is bad) I’m not sure your going to be able to get a hose into the tank easily.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 09-17-2021, 10:57 AM   #5
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
This.
And - there are two tanks that straddle the drivetrain, so if the fuel is high enough, you might not be able to drain enough with a hose out of that side.
'20 ZL1 Black "Fury"
Old 09-17-2021, 12:19 PM   #6
MartinLe
MartinLe's Avatar
Hey fellas,
Thanks for the advice. I will have to do the HP Tuner method. I can easily get the hose past the little metal gate and down the tube about 18 inches, but then it just stops like there is some sort of obstruction or maybe there are too many bends - who knows?
Thanks, again.
FIC+30%
Monster S Series
Elite E2-X
2" TSP LT's
Old 09-17-2021, 12:52 PM   #7
MartinLe
MartinLe's Avatar
Is it fairly straight forward in HP Tuners to command the LPFP to run? I haven't gotten into the program to change things. Any advice would be appreciated.
FIC+30%
Monster S Series
Elite E2-X
2" TSP LT's
Old 09-17-2021, 12:52 PM   #8
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
Hey fellas,
I believe that the fuel filler tube has a device to prevent fuel leaking out of the tank in the event that the car rolls over in an accident. That also prevents you from siphoning gas from the tank.
Old 09-17-2021, 12:58 PM   #9
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Under controls and special functions/fuel in the scanner. You can command the pump on/off.
Old 09-17-2021, 01:07 PM   #10
MartinLe
MartinLe's Avatar
Thank you, sir.
FIC+30%
Monster S Series
Elite E2-X
2" TSP LT's
Old 09-17-2021, 10:34 PM   #11
Wuiquen
Wuiquen's Avatar
Drives: 2018 Hot Red ZL1
How many fuel pump does the ZL1 have? How did you determine your fuel pump was bad?
Old 09-18-2021, 01:35 PM   #12
MartinLe
MartinLe's Avatar
There is a high side and low side fuel pump in the ZL1 Camaro. The high side is under the supercharger and feeds the high pressure fuel rails and it runs off cam. The low side fuel pump is in the gas tank and feeds the high side pump. It is a stand alone pump and runs off an electrical circuit.
My car started having a random misfire issue from no apparent cause. Right at 3500 rpm (under load) the car would fall on its face. Under easy throttle, it would run fine. So, I changed the plugs and wires. It seemed to correct it a little, but still had a misfire under load. I hooked up HP Tuners to it and took it for a drive.
Under load, the fuel pressure would drop crazy low, high and low side. Fuel rail pressure dropped below 1000lbs. I am running e60. I had about half a tank. So, I filled it up with premium and brought the e content down to e33. Took it for another run. Low side dropped like a rock, but managed to supply the high side and rail pressure stayed much higher.
I had Ted at Jannetty Racing take a look at the logs and he says swap out the low side fuel pump. Fun Fun Fun.
FIC+30%
Monster S Series
Elite E2-X
2" TSP LT's
Old 09-18-2021, 08:01 PM   #13
Wuiquen
Wuiquen's Avatar
Thanks for the info. Didn't know about the dual fuel pump.
Old 09-19-2021, 09:47 AM   #14
MartinLe
MartinLe's Avatar
FIC+30%
Monster S Series
Elite E2-X
2" TSP LT's
