09-17-2021, 08:29 AM | #1 |
BMR front and rear cradle braces
Does anyone know if the BMR cradle braces can be use with the zl1-1le solid lockout bushings?
09-17-2021, 09:51 AM | #2 |
Drives: HBM ZLE Join Date: Aug 2017
I have them on mine which is a 1le, not sure if they work with aftermarket solid bushings. But they work with oem zl1 1le bushings
09-17-2021, 10:58 AM | #3 | |
Petro-sexual
I believe the rear brace won't work, though, because of the eLSD controller being in the way.
09-17-2021, 11:27 AM | #4 |
Yep, sorry I'm getting off a 12 hour night shift and didn't see you said rear brace also. I only have the front braces, like radz28 said the rear braces won't work from what I read
09-17-2021, 11:29 AM | #5 |
Drives: 2019 Camaro ZL1 // 1LE Join Date: Jan 2020
Was considering adding this to my ZL1 1LE, so does the rear cradle brace bolt up, and do you feel like it made a difference. Someone just said the rear brace wont fit.
09-17-2021, 12:39 PM | #6 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
Front braces fit fine. Between the rear cradle bushings and the front cradle braces, why wheel hop is completely gone.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
09-17-2021, 02:43 PM | #7 |
Drives: '86 IROC-Z '18 ZL1 Join Date: Jul 2019
The rear brace won't work on a zl1 (or zl1-1le) but a front brace will fit fine. There is some Ect/controller or something like that on the zl1 rear end and that will cause the rear brace to not fit.
*that same ecu isn't present on ss's* |
