Old 06-28-2010, 12:57 PM   #1
MTI Racing Kevin
MTI Racing Kevin's Avatar
Drives: 2010 Camaro
MTI Racing Strut Tower Brace
MTI Racing has added the BMR Fabrication Strut Tower Brace for the 5th Gen Camaro. The 5th generation of Chevrolet's F-body is GM's most rigid platform to date however that doesn't mean it can't be improved upon. Strut towers are subject to more load than most people realize and even normal everyday driving can deflect the towers a measurable amount. Aggressive driving and especially track driving can move the towers around enough to create erratic handling inconsistencies and temporary alignment drift. Most of this load is directed inward as the strut/spring compresses and attempts to close the distance between the two towers. BMR's front Strut Tower Brace reinforces the front end by tying the two strut towers together, effectively canceling tower deflection.
BMR's Strut Tower Brace is manufactured from large diameter 1.75" x .120" tubing with heavy duty 1/4" thick mounting plates. Our braces mount directly to the top of the strut towers at the highest leverage point for the greatest amount of stability. The upper strut retainer is replaced with BMR's billet aluminum, high clearance retainer.
BMR Fabrication has designed two different strut tower braces, a 2 point brace and a 4 point brace. BMR's 4 point Strut Tower Brace goes a step further by tying the front fenders and core support together with the strut towers. BMR's 4 point links are made from 1" DOM tubing and use heavy duty 1" clevises and QA1 rod ends. Both versions available in red or black hammertone powder coat. NOTE: Does not fit V6 models. A 4 point strut tower brace for the Magnuson supercharger will be available soon.
Check this link for more info about the 2 point tower strut brace.
Check this link for more info about the 4 point tower strut brace.
Follow this link to the vendors area for pricing and availability.
Two point strut tower brace.
Four point strut tower brace.
MTI Racing Kevin is offline   Reply With Quote
1993-02 Camaro/Firebird Shock Strut Tower Brace dpizzardi Suspension / Chassis / Brakes 0 06-15-2010 07:40 PM
Hotchkis Strut Brace Install Photos on SC Camaro Hotchkis Suspension / Brakes / Chassis 8 04-16-2010 11:22 AM
MTI Racing Review (Camshaft, Gears, Suspension, Handling) Deric884 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 04-14-2010 08:11 PM
589RWHP Daily Driver by MTI Racing MTI Racing Kevin 5th Gen Camaro SS LS LT General Discussions 10 04-14-2010 09:08 AM
