11-15-2023, 11:41 PM | #1 |
Drives: Camaro SS Join Date: Aug 2023
My engine is getting dirty
Can I spray it down with a bottle of engine cleaner then safely spray it at low pressure at a self service car wash?
11-15-2023, 11:59 PM | #2 |
2020 Shadow Gray 2SS
If you keep up on it you never have to get too far into it... Here is my engine with nearly 9,000 miles...
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
11-16-2023, 03:30 AM | #3 |
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
Engine cleaner is very aggressive, it's designed to remove baked on oil/dirt. I would use something like Simple Green or Turtle Wax Maxpower and then spray with WD-40, nothing under the hood is going to be effected by water spray.
11-16-2023, 05:10 AM | #4 |
Simple Green and say bye bye to the red lettering on the coil pack covers after a few years
11-16-2023, 07:05 AM | #5 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
low pressure clear water works perfectly well, you really shouldn't have a grease and oil problems that needs a "cleaner".
11-16-2023, 09:22 AM | #6 |
Drives: 2020 Cadillac CT5 V and 87 Buick GN Join Date: Dec 2008
A word of caution for you. Be very careful to avoid spraying even low water pressure directly on the red CAMARO lettering on the beauty covers. I’ve ruined two sets now thinking extremely low pressure garden hose water wouldn’t have any effect. Painted flaked right off.
2SS, Nightfall Gray, A8, MRC, NPP, NAV, Blk Bowties
Gen 6 1100 01-22-2016 2000 03-22-2016 3000 03-25-2016 TPW 4/11 3400 04-01-2016 3800 04-08-2016 - Built 4200 04-08-2016 6000 04-20-2016 Gen 5 1100 04-22-2009 2000 05-15-2009 2500 05-19-2009 3000 05-21-2009 3400 06-10-2009 3800 06-18-2009 4150 06-18-2009 4200 06-19-2009 4800 06-29-2009 4B00 06-30-2009 5000 07-10-2009!!! |
11-16-2023, 10:48 AM | #7 |
Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
My engine with 15K on it.
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, AWE Touring, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
11-16-2023, 11:33 AM | #8 |
Drives: '23 Sharkskin Gray LT1 RS "JAWZ" Join Date: Aug 2022
I have been cleaning the engine bays in my cars for years and never had a problem with bagging the alternator, intake, and ECU. I use a diluted APC (All Purpose Cleaner), which is different than a degreaser, which is much harsher. My go to right now is DIY Detail APC. I spray the APC on very light and use a soft bristled brush to agitate grimy areas. Using my Ryobi electric power washer using the 40 degree tip, I spray away the dirt and grime, making it a point to keep the wand moving and not flooding any particular area with water. I use my air compressor to blow away any excess water, spray on a finishing detailer and wipe it all down.
One of the most important things to remember is not doing this while the engine is hot. Allow it be cool to the touch and you should be just fine. Kind of interested to know what technique's other people are using. |
11-16-2023, 11:58 AM | #9 |
Long hauler
Worst I’ve cleaned was my sister’s old 2014, she came home after living in Glendale, AZ for a year or two. I used light water from a little gardening water bucket, Simple Green and a medium brush from Walmart.
11-16-2023, 12:27 PM | #10 |
Drives: 70 GTX, 06 Mustang, 22 Camaro LT1 Join Date: Jan 2022
Tub o Towels work great to clean it up if its real dirty - might use 2 or 3 and have the rest for another time... otherwise I just use Optima No Rinse diluted 265:1 with a microfiber rag.
https://www.amazon.com/Wonder-Works-...d6527a4b2&th=1
2022 CAMARO LT1 COUPE AT10
11-16-2023, 02:57 PM | #11 |
Drives: 2022 2LT RS Convertible Join Date: Apr 2021
Just water and a little elbow grease. 18,000 miles.
11-16-2023, 04:14 PM | #12 | |
11-16-2023, 05:22 PM | #13 |
OSCM(SW) USN Ret.
Drives: 2023 Camaro 2SS-1LE VOM 6M Join Date: Apr 2023
What and where did the info plate come from???
2023 2SS-1LE VOM, 6M, SR S-TBrace, A-PDL's, Fuzzy suede KP's, NAV
1100 3/29/23 2000 3/30/23 3300 5/1/23 3800 5/4/23 4200 6/1/23 6000 6/6/23 |
11-16-2023, 10:37 PM | #14 |
Chris at DeadBrand Designs...
https://deadbranddesigns.com/ VERY good quality, well worth the price (~$80) he will customize it any way you want and send you a proof before he makes/ships it... Solid dude...
