Old 02-04-2021, 11:33 AM   #1
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
SEAT BRACKETS FOR RACE SEATS
been looking at adding race seats to my 1ss in the last few months and talking to studio rsr in socal about full cage rear seat delete seat and harness and just looked up brackets today and saw planted or brey krause anybody know main difference between the 2 other than price?
planted
https://www.plantedtechnology.com/pl...favp120b0e2gv5
brey krause
https://www.bkauto.com/R_9170_2016_6...r_p/r-9170.htm
it appears both of them work with sliders and this is the seat i was looking at btw its the sparco qrt r
https://studiorsr.com/collections/ca...arco-qrt-r-red
Old 02-04-2021, 01:39 PM   #2
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
I'm in the process of figuring all this out using the BK mount which allows you to retain the stock belts if you want for street driving. Biggest problem so far is getting the right seat mounts for the height you like that will also work with the mount and the slider. The mounts in this picture are too low for me and I'm 5'-10. Trying to get other side mounts with BKs help.
Just a bit of a puzzle
Old 02-04-2021, 01:48 PM   #3
kropscamaro16
aww i was just talking to a guy other day and he said he had the planted ones and he couldnt use the oem belts, im 6ft tall and not sure about height so i guess its trial by spending $$ ?
Old 02-04-2021, 03:03 PM   #4
carguy55
carguy55's Avatar
I'm very close to having it figured out just need higher seat side mount brackets.
The side mounts you need vary by seat model and Lee at BK has been very helpful <lee@bkauto.com> figuring out what's needed.
May take a day or 2 for him to answer.
If you're a NASA member you can save a lot (15%) by buying from competitionmotorsport.com
Old 02-04-2021, 03:30 PM   #5
carguy55
carguy55's Avatar
Going to get this figured out tomorrow and will let you know the outcome, but you have a different model Sparco seat
Old 02-04-2021, 04:09 PM   #6
kropscamaro16
oh nice thanks for the info and i am member of nasa/scca
Old 02-07-2021, 06:23 AM   #7
carguy55
carguy55's Avatar
After spending a couple hours at competition motorsport and working Friday and Saturday on it, I still don't have a solution that's working for this combination on parts. Looked at a bunch of different side mounts and still no go. Problem is getting side mounts that fit the seat and work with the BK Seat Track Adaptor/slider assembly which has its own set of issues. BK sent side mounts that fit but are too low and said that's all they have. Going to call Sparco Monday to see what they say but it takes a unique style side mount to work with BK Seat Track Adaptor.
Old 02-07-2021, 02:46 PM   #8
Baddawg53
Drives: 17 hyper blue 2SS M6
Man, I guess I got kinda lucky getting the parts I have. Had to ditch the sliders for headroom, but it all kinda fit together. One hole on each side bracket had to be drilled out, but it was minimal modification overall. It's a puzzle putting it all together, not like buying GM parts that were made specifically for the car.
Baddawg53 is offline   Reply With Quote
Old 02-07-2021, 03:03 PM   #9
carguy55
carguy55's Avatar
After working on it the past 3 days it's put together and in the car. Had to elongate the slots on the side brackets, drill 2 holes in the sliders, get some spacer for between the seat and side monuts, longer screws and more washers. Forget having the ultimate driving position adjustment and comfort of the power seats. This driving position is a compromise and will take time to get used to. Have to get the harness now and make sure to get ones with lap belt adjusters by the buckle and not the ones on the sides because they will hit the seat. The left side seat belt/harness attachment is not shown in this pic, it has to go in after the seat is mounted.
I had some of the same issues shown here
https://www.camaro6.com/forums/showthread.php?t=511468
Old 02-07-2021, 09:36 PM   #10
Baddawg53
Nice work, looks good 👍...
I had to cut the lap belt mount off the harness bar to mount the stock belts, are you using the stock belts too?
Old 02-09-2021, 02:39 PM   #11
carguy55
carguy55's Avatar
Yes I'm keeping the stock belt capability for when I drive on the street. Which is the big benefit of the BK mounts.
If you use the BK Harness bar they have one for stock seats R-1155 and one to mate with their race seat mounts R-1156. The bars on the stock seat ones have a harness mount tab. They also offer a kit for converting from stock to seat mounts.
Old 02-09-2021, 07:18 PM   #12
Baddawg53
Ahhhh.... I'm sure that's where I messed up then. Gotta do more research sometimes.
Old 02-10-2021, 12:01 PM   #13
carguy55
carguy55's Avatar
Did you mount your seat level on the side seat mounts or tilt it back 1 hole? Seems to be almost too much of an upright position using level mounting holes in the side seat mounts.
Old 02-10-2021, 12:23 PM   #14
Baddawg53
Oh I leaned them back, I think 2 holes actually. It was definitely way to upright mounted even. Very uncomfortable.
