06-09-2020, 09:52 PM | #127 |
Drives: Black 2019 ZL1 M6, Join Date: Sep 2019
https://www.speedwaymotors.com/Mobil...it,386340.html
Here, 12 quarts and oil filter for 104$ + FREE SHIPPING
2019 Black ZL1, M6, CF Hood and Dash, Nav System, ZL1 Addons rock guards and lift points, Michelin Pilot Sport 4S, DD Smoked Marker Lights, Ceramic window tint, Gtechniq 9yr ceramic coating. JL Audio stealth box 12W6, Dyanamat trunk, Dead pedal cover, Soler TB/TC, Green Filter, Carbon-fiber Borla S-Type
06-10-2020, 05:25 AM | #128 |
Drives: 2017 ZL1 Join Date: Apr 2020
Thanks Puppykat33
06-10-2020, 06:48 AM | #129 |
Drives: ZL1 1LE Join Date: Jul 2019
George, I had a pump failure and had the European oil in the car!
I suspect that is the case and I am located in Europe. Need to special import the oil in order to get it right. What are my options? |
06-10-2020, 07:32 AM | #130 |
Yea man . thats the best price i have found and its free shipping + every 5 oil changes you have enough left over to do a oil change with the extra so win win
06-10-2020, 08:09 AM | #131 |
Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
I just re-read the title of this thread. And I don't remember noticing the "possible oil pump failure" line.
When I had my oil pump failure and replacement, neither the mechanic that replaced the pump nor the service manager said anything about switching back to 5w30. So, where is the evidence that the 0w40 esp oil could be the source of the failure? I would have hoped that the dealer would have said something to me about this if this were true...
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
06-10-2020, 08:38 AM | #132 |
Is the engine still running good and seeing no oil pressure issues Steve? I guess you are good to go with the 0w40 oil if neither one mentioned switching back to 5w30.
06-10-2020, 09:05 AM | #133 | |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
Nor does "European 0W-40 oil" (i.e. oil that meets Mercedes and various European standards) have anything to do with failure of a GM oil pump. |
06-10-2020, 09:14 AM | #134 | |
Now, in truth, I had the 0w40 esp oil in it when it failed. The obviously had to drain the oil to pull the pan off. No where in the paperwork do I see what they put back in it. So, I supposed it could be 5w30. But I really do NOT know.
06-10-2020, 09:19 AM | #135 |
Looking over the invoice again, I see where they put 10 qt of oil in it. I just tried to look up the part number on the "thatgmpartsguy" website. But is just says oil, there is nothing about viscosity there...
06-10-2020, 10:32 AM | #136 |
To fast is not enough
Drives: 2019 ZL1 Camaro & 2020 CT5-V Turbo Join Date: May 2019
Steve that is 5w30 mobil 1
06-10-2020, 01:25 PM | #137 |
As Hell Raiser stated it’s 5w30 so that’s probably what they put in your ZL1 since it’s the recommended oil for your 2018.
06-10-2020, 06:40 PM | #138 | |
ZL1 Driver
Drives: Camaro ZL1 & BMW M3/E92 Join Date: May 2009
Thank you to everyone for their input. |
06-10-2020, 06:42 PM | #139 |
ZL1 Driver
I would definitely get a warranty review and see if the dealer put that oil in your car. It seems Dexos2 0w/40 oil is in Europe. In an earlier post, someone in France found Castrol 0w/40 Dexos 2 at 53Euro for 5 liters. I would look for that. If you are military, I used to get some car stuff shipped to my APO address but you should check with them on base first.. I would also use Amazon (Europe) if you can't find it in stores.
06-10-2020, 07:27 PM | #140 | |
0.8% sulphated, typical of dexos which is double the price |
