Old 12-05-2018, 06:51 PM   #1
eaglesfan2006
Drives: 2019 1SS 1LE Riverside Blue
Other lift points besides pinch weld points?
Is there any other points that can lift the car?
This is a tempary lift. Was hoping to remove my wheels and deep clean and protect for winter.
eaglesfan2006 is offline   Reply With Quote
Old 12-05-2018, 07:02 PM   #2
eaglesfan2006
In the rear by one of the pinch welds, there is this point that connects to what looks like part of the frame.
I don’t see any other viable options that can support the weight of the car.
Let me know if I’m missing something.
Old 12-06-2018, 09:28 AM   #3
Gunmetalmissle
Drives: 16 ngm ss
Is this for a jack or an actual lift? You can use a jack on the pinchwelds and also under the rear diff. A lift that distributes the load can be used with wooden blocks on the front aluminum subframe and and black bars you pictured in the back. The zl1 addons pinch weld adapters also help.
Gunmetalmissle is offline   Reply With Quote
Old 12-06-2018, 01:59 PM   #4
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
DO NOT JACK UNDER THE REAR DIFF!
I'm hoping you meant to refer to the rear crossmember behind the diff.
Old 12-07-2018, 11:43 AM   #5
CoolbreezeNJ
Drives: '18 Hotwheels 2SS
Go to ebay and for $14 you can get the pinch weld adapters. IF you place those adaptors about 2 ft back from the front wheel you can raise the whole side of the car so you could do a front to rear tire rotation if you tire sizes are correct.
I wouldn't jack that rear end either.
CoolbreezeNJ is offline   Reply With Quote
