05-21-2023, 08:02 PM | #1 |
Drives: 2023 Camaro RS 3LT V6 Join Date: Apr 2023
2000 Status
I have been at 2000 status since 5-11. So that is 10 days now. Should the dealer have gotten notification by now of any constraints? Would GM have accepted the order even though there was constraints? Or do I need to be at 3000 status to be safe from constraints? I hear conflicting info sometimes about if you are at 2000 status then there should not be constraints. But others have said you have to be in 3000 status to be safe? Any insight?
2023 Black RS 3LT Coupe V6 - NPP, Carbon Flash Black Wheels, Sunroof, Adrenaline Red Interior
05/04/23: Order placed 1100: 5/04/23 2000: 5/11/23 3400: 5/31/23 -- TPW 6/12/23 3800: 6/13/23 (My Birthday!) 4200: 6/16/23 5000: 6/28/23 |
05-21-2023, 09:14 PM | #2 |
OSCM(SW) USN Ret.
Drives: 2023 Camaro 2SS-1LE VOM 6M Join Date: Apr 2023
I just checked for any Camaro constraints, as of 2215 Est. There are none listed.
05-21-2023, 10:48 PM | #3 |
Where do you check that, if you do not mind me asking?
05-21-2023, 10:55 PM | #4 |
OSCM(SW) USN Ret.
https://www.gmfleetorderguide.com/NA...&divisionID=3#
select distribution tab. |
05-22-2023, 12:31 PM | #5 | |
Drives: 2023 Camaro LT1 Join Date: Apr 2023
05-22-2023, 12:50 PM | #6 | |
Drives: 2016 Chevy Camaro 1LT Join Date: May 2023
05-22-2023, 06:30 PM | #7 | |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
That shows you nothing about model or option constraints. Constraint information is only available in WorkBench or whatever the new software is called. The report looks like this...
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
05-22-2023, 07:28 PM | #8 |
I will keep you posted for sure! Are you getting the NPP Exhaust or Sunroof?
05-22-2023, 10:06 PM | #9 |
Would DC Sales be able to look the constraints up?
05-23-2023, 11:42 AM | #10 | |
And no on the sunroof - I've never really found myself using it that much, and I kind of prefer the look of the roofline without it. On another note - not sure if this is a dumb question but does anyone know if constraints are still a potential hurdle if your order is already at 2000 status? Does the constraints choke-point happen at moving from 1100 to 2000, or from 2000 to 3000s? |
05-23-2023, 12:37 PM | #11 | |
Drives: 2023 2SS Convertible Join Date: May 2009
-Geoff
05-23-2023, 01:13 PM | #12 |
Ah that's good to know. I got auto.
05-23-2023, 06:57 PM | #13 |
Could you elaborate on the AFM Valve? Is that what shuts off cylinders? I watched Youtube videos of Automatics with NPP and you could hear the exhaust decently.
05-23-2023, 07:21 PM | #14 | |
On a non-NPP V6 auto there are two AFM valves, and on a non-NPP V6 manual there are NO valves. Even though they still flow pretty good, the AFM valves still drop the sound down. I heard them both, and the manual sounds incredible! The auto sounds good, but not near as good. That was in 2016, and I haven't crawled under one and counted valves since, although I doubt it has changed. -Geoff
