03-08-2021, 08:40 PM | #1 |
Drives: '17 ZL1 A10 Vert Join Date: Mar 2017
Washing with well water
Anything to be concerned about using well water to wash the car?
I just moved. No more city water/sewer. I don’t know if there’s anything in the water to worry about. It definitely tastes different. I normally do a rinseless with about a dozen microfiber towels. Water never sits on the car for more than a few minutes. |
03-08-2021, 09:07 PM | #2 | |
03-08-2021, 09:36 PM | #3 |
Drives: 2021 camaro ss Join Date: Oct 2020
Depends on depth of the well and water condition. Some of the areas I service no way in h*ll would I wash my car in it. Shallow wells here have large amounts of iron oxide in them and will turn cars and concrete orange. Hard water which is the other problem here can be just as bad. My professional advice to you would be have your water tested and find out where you stand.
03-11-2021, 06:38 AM | #4 | |
Thank you Al Oppenheiser!
Solution: don't let water dry on the car. |
03-11-2021, 08:56 AM | #5 |
Drives: 2021 LT1 Join Date: Aug 2020
This isn't cheap, but I always wanted to try these (Portable Water Deionizer):
https://www.griotsgarage.com/product...r+deionizer.do |
03-11-2021, 11:14 AM | #6 |
Drives: 2017 Camaro SS 1LE Join Date: Oct 2018
Similar to the above, I use this one:
https://crspotless.com/product/simple-chuck/ You can, in theory, let the water dry on the paint with no ill impacts. I do still dry my cars. |
03-11-2021, 12:47 PM | #7 | |
I see these kits and they're only good for XXX number of gallons but I have NO idea how much I use for a single wash of a car. Or do you only use these for the final rinse? |
03-11-2021, 04:23 PM | #8 |
Two Lane Blacktop
Drives: '18 Camaro 2SS Join Date: Jul 2019
If you have a softener which is very common, you will want to dry it to stop the residue. Just a side note, you should have it biologically tested if you don’t have a recent one. Couple ways to treat bad water UV light or a chlorinator. Harder to clean up the lines if contaminated water sat in the house lines.
Sulphates while it smells and tastes bad normally means it drinkable. I have had wells drilled and lived on a few, current house was converted to municipal water which is still hard. |
