11-08-2019, 09:45 PM | #1 |
Drives: 2019 Camaro SS 1LE Join Date: Mar 2019
Going to install an aftermarket exhaust with NPP
Hi guys, i'm going to switch out my OEM NPP for some Flowmaster American Thunder axleback equipped w/ NPP. I am planning to do the install myself but my question here is: is it as simple as unplugging the OEM NPP plugs out of the car and plugging in the Flowmaster NPP plugs in? Or is there more to is than just that? Also, anyone know how the Flowmaster American Thunder axleback is? Compared to MBRP and Borla or other aftermarket exhausts? Does it drone?! If so, is it bad or chill?! This one is a good deal for an NPP axleback!
THANK YOU |
11-08-2019, 10:19 PM | #2 |
Thank you Al Oppenheiser!
You unbolt the actuators from your current exhaust and reinstall on the new.
Here are the instructions so you can RTFM. |
11-09-2019, 06:55 AM | #3 |
I ran the Flowmasters for about a week, drone was unbearable. Switched to Borla. Absolutely perfect now.
11-09-2019, 09:50 AM | #4 |
Drives: 2017 1LE Join Date: Nov 2017
Ha. Drone. None...that fake noise sound tube is worse. Get rid of that while you're at it. IMHO
'17 Bright Yellow 1LE. PDR, STB, !CAGS
Borla 60606, 11925. Tony Mamo ported TB, ROTOFAB, !Sound Tube |
11-09-2019, 10:12 AM | #5 |
Disconnect the the NPP actuators, put jack stands under the muffler, measure and cut the 2 pipes, unbolt hanger brackets for muffler, remove muffler, swap NPP actuators over to the FM NPP, Install FM mufflers...etc I would use some permatex ultra copper around the joining pipes before clamping them down.
*The flowmaster NPP exhaust comes with instructions that are clear and concise. It's super easy to install. Just make sure you have a good sawzall blade before cutting the pipes and use a file to clean the edges after the cut. The drone is very minimal to non existent with the valves closed. If you drive with the valves open, expect some drone around 1500rpm. It's not bad and lets you know that you have bald eagles under the hood instead of V-tech.
2016 NFG 1SS A8
11-09-2019, 10:37 AM | #6 |
Drives: 2019 ZL1 / LE , 2014 CTS V Join Date: Nov 2015
Ill be looking at adding a axle back on my ZL1/ LE in the next few weeks. Im waiting to see what options I have come Black Friday. All the research Ive done on the NPP installs everything seems pretty straight forward. It probably makes things more pleasant if you had a lift. Im leaning towards Borla or Stainless Works just due to the fact that at somepoint Ill have a complete system with headers underneath it and I want everything the same manufacture. I had a Borla system on my Gen5 SS a few years ago that I installed myself and everything went together very well.
11-09-2019, 11:55 AM | #7 |
11-09-2019, 12:44 PM | #8 |
11-09-2019, 12:44 PM | #9 |
11-09-2019, 12:46 PM | #10 | |
Thanks so much! Lol at the last part. Enjoyed this very helpful message! |
11-09-2019, 12:47 PM | #11 | |
11-09-2019, 03:30 PM | #12 |
Drives: 2022 Wild Cherry SS Join Date: Aug 2012
FYI - I had the MBRP on my 17SS and replaced it because the drone was way too loud!
11-09-2019, 06:13 PM | #13 |
11-09-2019, 08:12 PM | #14 |
It was for me. But it's my daily driver, and I do a lot of around town driving. It was all drone for me, ringing ears every time I stopped. Once you get out on the highway and crusing or wot, it's not so bad. It had to go.
