05-06-2017, 02:45 PM | #29 |
I love crepes
05-07-2017, 07:35 AM | #30 |
Drives: 2016 Camaro 2SS, Red Hot Join Date: Feb 2014
Can't you do it like the corvette, plug it into a 12volt outlet
05-07-2017, 07:56 AM | #31 |
Drives: 2017 Camaro SS Convertible 50th Join Date: Nov 2016
05-07-2017, 06:06 PM | #32 | |
Drives: 2016 Camaro 2SS, Nightfall Grey Join Date: Nov 2012
https://www.amazon.com/CTEK-56-263-C.../dp/B0016LA5O8
2016 Camaro 2SS, Nightfall Grey,
MRC, NPP, S/R, Nav, A8, E-Force Supercharged. |
05-16-2017, 07:51 PM | #33 |
Drives: ZL1 Join Date: Jun 2012
It would have been a whole lot easier if it plugged in the trunk like my Z06.
2018 ZL1 Vert
2018 Dodge Demon |
05-17-2017, 05:34 AM | #34 | |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
CTEK is OEM battery chargers supplied with Porsche's, Konigsegg's, Corvette's, etc. Top grade stuff.
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
10-06-2019, 01:25 PM | #35 |
Livin' the dream Plan B/C
I bought a panel mount one for my 18 ZL1, have it hardwired to the battery in the trunk, ran the wires through the inside of the trunk paneling and have the panel mount sae connector mounted to my rear bumper right next to my license plate light. So all I have to do is plug it in, no popping trunk or hood, and you cannot notice it unless you look up at the plate. It’s clean and easy, took a couple hours to do it but worth it in the long run. I’m gonna do it to the rest of the fleet I think over the winter
11-11-2019, 10:56 PM | #36 |
Drives: 2020 2ss vert Join Date: Oct 2019
Battery Tender
Mine is hooked up to the posts under the hood. On the 2020 there are 2 small holes in the shield under the front just below the fuse box. I fished the wire up from the forward hole. Tender is outside the car and the hood is closed.
11-12-2019, 03:58 AM | #37 |
Drives: 2017 Camaro SS Join Date: Nov 2018
I've used the Battery Tender brand on my motorcycles for years. What brand and model tender are you guys using?
Kevin
Luceo Non Uro |
11-12-2019, 08:57 AM | #38 |
Drives: Chevy Camaro Join Date: Jul 2019
Make sure you get a real tender so when it's topped of is stops sending voltage to the battery, I have seen tenders cook the water out of a battery stored over the winter, Shumacher makes a good tender
11-12-2019, 09:49 AM | #39 |
11-12-2019, 09:57 AM | #40 |
I use a Bettery Tender Jr connected under the hood.
2016 NFG 1SS A8
11-13-2019, 04:15 AM | #41 |
Drives: 2017 ZL1 - Hyper Blue Join Date: Mar 2015
CTEK MUS4.3 is what I'm using. Really happy with it.
Sent from my Pixel 2 XL using Tapatalk |
11-13-2019, 06:11 PM | #42 |
NOCO Genius + 10’ cord extension. Charger mounted and plugged in at ceiling above car. Attach and detach extension to charge under hood. Good quality.
