09-17-2019, 09:29 AM | #1 |
Drives: 2015 Chevy camaro 2lt w rs Join Date: Mar 2019
Brembo conversion
Was curious if there’s a certain year I need of the Chevy brembo calipers, or if 2016 will work. Asking because I’m looking at used calipers and a 2016 is the best quality one I’ve found so far. Chime in.
09-17-2019, 11:26 AM | #2 |
Drives: 2012 Camaro RS 2LT 6spd man Join Date: Aug 2013
6th gen calipers will not work on 5th gen, since they are a whole different body and chassis. Any 5th gen SS or ZL1 caliper will work. with of course, new caliper mounting bolts, rotors, brake lines. and of course modification/replacement of the brake rotor heat shields, most prominently in the rear on the V6's. I didn't have to do anything to any shields in the fronts on my last 2 5th gens.
09-29-2019, 11:15 PM | #3 | |
Consistently inconsistent
Drives: 2015 2LT Summit White Join Date: May 2015
I wish I could find the CTS/CTS-V part numbers... crap.
Thanks to MRR, I have some SWEET wheels! Thank you!
2015 2LT Ported TB, Ported intake, JACFAB intake spacer, Borla exhaust, IPF 91 tune, Complete 1/LE suspension, Brembo brakes, Goodridge lines, Elite catch can, CAI with Thermo-wrap, 275/40-20 x 10's all around, Z/28 spoiler, GM splitter, Alpine/Polk stereo with AudiControl interface. |
09-30-2019, 03:02 AM | #4 | |
It don’t come easy.
10-12-2019, 07:10 PM | #5 |
Drives: 2012 camaro Join Date: Nov 2011
getting things ready for bembro convertion. from a 2012 Camaro ls to I'm guessing ss?
I go the calipers powder coated the same color as car inferno orange.... but today I want over to my Chevrolet dealer in town, I wanted to purchase the discs, brake pads. break lines, bolts to hold down the caliper for all around the the car. but the employee was asking me all these questions about the caliper sorry don't have any anwsers I just know that the bembro caliper from a 2010-2014 Camaro ss fit a 2012 Camaro ls I also know that the bolts to hold down the bembro calipers are different from the stock ls employee did not really know what to give me so he asked me to bring in the bembro calipers..... so can anyone help me out with a part # for discs front n back. bolts for calipers front n back. break lines for front n back. break pads for front n back. and if I need anything also just let me know |
10-12-2019, 09:11 PM | #6 |
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
rockauto has them for around 215 per caliper
you can get a used set all 4 with rotors for round 500 from a guy i know, he ships call him The Shop 2016 N Tryon St Charlotte NC 28206 (704) 333-2696 |
10-13-2019, 02:41 AM | #7 |
Anybody have part numbers for
Discs, brake pads and brake lines for the bembro caliper kit |
10-13-2019, 05:03 AM | #8 |
Drives: 2014 Ashen Gray Convertible Join Date: Apr 2017
Brembo conversion parts for 2010-2015 V6, GM part numbers:
Part Part Number Camaro SS Master Cylinder 22956541 Crush gaskets hose assembly 21012386 Bolt front caliper (4) 11570788 (Torque to yield, 30 ft pds plus 90 degrees) Bolt rear caliper (4) 11515781 (Torque to yield, 30 ft pds plus 90 degrees) Rear axle nuts (2) 11611687 (Torque to yield nuts, 199 foot pounds) Brake line bolts (banjo) 11569590 Brembo bleeder valves/cover 25900782 Rear right brake shield 23131778 Can find used on eBay, much cheaper Rear left brake shield 23131777 Can find used on eBay, much cheaper Hose assembly rear brake (2) Hose assembly front right brake 92229712 Hose assembly front left brake 92229713 Pad kit, rear disc brake 89047744 Pad kit, front disc brake 22907156 Pin kit, front disc brake 89047711 Brembo caliper right rear (P) 92233176 Brembo caliper left rear (D) 92233177 Brembo caliper right front (P) 92244288 Brembo caliper left front (D) 92244287 Rotors front Brembo brakes 92245928 Rotors rear Brembo brakes 92245929 Gen 5 SS brake upgrade for V6 models with Brembo front and rear brake components from the SS. Front rotors are 14" diameter, compared to the 12.6" V6 rotors. Wheel the rear rotors are 14.4" compared to the 12.4" V6. Gen 5 Camaro V-6 to ZL1 Brake Conversion Kit Front & Rear) Upgrade the brakes on your 2010-2015 Camaro V-6 to the system used on the supercharged Camaro ZL1 - including racing-style two-piece, 14.6 front rotors with six-piston Brembo(R) front calipers, 14.4-inch rear rotors with 4-piston Brembo(R) rear calipers and a V-8-specific master cylinder. That compares to the 12.6-inch front and 12.4-inch rear rotors and single-piston sliding calipers on V-6 models. NOTE: Requires 20" wheels for caliper clearance. The front system includes: 22960684 (1) Front Installation Sheet 20795300 (1) ZL1 Front LH Rotor 20944529 (1) ZL1 Front LH Caliper 20944530 (1) ZL1 Front RH Caliper 25940448 (2) Front Caliper Pin Kit 25940447 (1) Front Service Pad Kit 20944523 (1) ZL1 Front LH Hose 20944532 (1) ZL1 Front LH Shield 20795302 (1) ZL1 Front RH Rotor 20944522 (1) ZL1 Front RH Hose 20944531 (1) ZL1 Front RH Shield 11570788 (4) Caliper to Knuckle Bolts 11569590 (2) Front Hose Bolts 21012386 (4) Front Hose Washers 22942442 (1) Chevrolet Perf. Badge The rear system includes: 22989385 (1) Rear Installation Sheet 11515781 (4) Rear Caliper-to-Knuckle Bolts 92245929 (2) Rear Rotor 20944518 (1) ZL1 Rear RH Caliper 20944519 (1) ZL1 Rear LH Caliper 89047744 (1) Rear Pad Kit 89047728 (2) Rear Caliper Pin Kit 23131777 (1) ZL1 Rear LH Shield 92229716 (2) ZL1 Rear RH & LH Hose 23131778 (1) ZL1 Rear RH Shield 21012386 (4) Front & Rear Hose Washers 22956541 (1) V-8 Master Cylinder 11569590 (2) Rear Hose Bolts
10-13-2019, 10:13 AM | #9 |
"up grading" large heavy breaks on to a car with less power and weight will increase un-sprung weight.i see drag guys upgrade or down grade to v6 rear brakes. i would leave it stock.
10-13-2019, 10:19 AM | #10 | |
The BBOMG fill-in husband
Drives: 2015 2SS/RS 1LE AKA V1LE Join Date: Aug 2010
UPSTATE C5 MEMBER
10-13-2019, 10:20 AM | #11 | |
UPSTATE C5 MEMBER
10-14-2019, 11:40 PM | #12 |
thank you. Deputy347k9 for the list of goodies
I went over to the dealership to buy some parts. they told me everything is special order n that gm is on strike that who knows how long parts will take to arrive. |
10-15-2019, 08:42 PM | #13 |
Back in August of this year, before the strike started, I ordered 8 front SS caliper bolts, 8 rear bolts and 16 crush washers just to have them on hand, so happy I did.
