Old 06-20-2019, 03:03 PM   #1
HouseStark
Drives: 2018 Camaro SS 1LE
Went Drag Racing the Other Day
Wanted to see if any other 1LE guys wanted to share their experiences or knowledge on drag racing our cars. Yesterday was the first time I took my 1LE to the strip since purchasing it last October. Had a decent enough experience. I know I can get more out it but I need to get more acclimated with the car.
- 13.7 w/launch control Track Mode/Race
-13.42 w/out launch control Sport Competitive Mode
-13.46 w/out launch control Sport Competitive Mode
- 13.65 w/out launch control Track/Race Mode
- Terrible launch guy next to me jumped the tree and through me off.
- 13.68 w/out launch control Track/Race Mode
- The final run was very weird. I feathered the clutch like in Sport Competitive and progressively got on the throttle then boom the computer came down like a hammer and cut me off at the jump. Any thoughts on this? My best runs seemed to come from Sport Competitive.
-Also, as a final note on my best run fuel cut off kicked in like 5900-6100 rpm in first anyone else experience this? The rest of the night I shifted out of first at 5500. The rest of gears flew to 6600 no problem. Car only has 900 miles could this be why?
HouseStark is offline   Reply With Quote
Old 06-20-2019, 03:55 PM   #2
biker2k
biker2k's Avatar
Drives: 2018 2ss 1le
what was your mph
were you spinning badly on all of the launches
are you located in high altitude...
I get the cutoff in track mode sometimes... too intrusive I like competitive mode better
2018 2ss 1le roto fab dry, Stainless works 1 7/8 lt to 3'" x pipe with highflow cats to stock npp, soler 95mm t/b, edelbrock 2300, LT4 fueling , jms bap and dsx flex fuel, 618/620 on e45 rwhp
Jannetty Motorsports tuned
biker2k is offline   Reply With Quote
Old 06-20-2019, 04:36 PM   #3
GuywithL86
Drives: Black
So I have the same engine as you in my 5500lb pickup truck. Well mine is down 40hp but I have a tune so lets say I'm only down 10hp.
I ran a 13.9 my first and only pass at an actual drag strip, DA was like 100 @ atco
those are some really bad times!
GuywithL86 is offline   Reply With Quote
Old 06-20-2019, 04:55 PM   #4
z28pat
z28pat's Avatar
Drives: 2002 z28, 2018 2ss 1LE
The et is more about traction and skill but mph will give you an idea of the power the car is making, what was your mph has already been asked.
The lt1 makes its power at 6000rpm so if you’re having to short shift in first then that’s already slowing you down .
z28pat is offline   Reply With Quote
Old 06-20-2019, 05:00 PM   #5
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I have a 2SS and not a 1LE, but I ran 12.1 bone stock. So I’m assuming once you get your launch and shifting down pat, you should be within spitting distance of my time.
Joshinator99 is online now   Reply With Quote
Old 06-20-2019, 06:24 PM   #6
kd7895
Drives: 2018 1SS 1LE
I have a 2018 1LE with LT's, Exhaust, Tune (Pray) and Cold Air. No dyno time. I heat the tires pretty good to have any hope of traction. Traction and Stability off, track mode. Looking back at PDR I launch around 5000rpm, shift just past 6000 and in Orlando it ran 11.97 @ 117 in May with warm weather but 1.80 60'. It ran 11.12 @ 117.49 mph in Cecil, Georgia 2 weekends ago with same weather, but the best I could get 60' was 1.94.
FWIW, with 61% Alcohol (E85) it ran 118.54 mph in Cecil, but I couldn't get a good launch so it was a 12.30 pass.
Otherwise, it runs 12.20s to 12.40s with 2.0-2.20 60'.
It takes a pretty hard slippage of clutch to get it just right.
Hope this helps.
kd7895 is offline   Reply With Quote
Old 06-20-2019, 10:36 PM   #7
Tim M
Times certainly vary even for a stock car.
I turned everything off on my stock 1LE and struggled to get a 12.8 @ 112 mph. My 60 foot was 2.05. I'd hope I could get the launch down to a 1.9...but not that night.
I've had no engine cut out issues. You mph will tell you if you have a HP problem.
Tim M is offline   Reply With Quote
Old 06-20-2019, 10:45 PM   #8
eimarshall
eimarshall's Avatar
Drives: 2018 SS 1LE Hyperblue
I ran a 12.7 at 113. Last summer. I turned off all nannies and dropped from 13.1 to 12.7. The tcs system didnt like hard launches and constantly killed any decent launch. I think its designed to let the rear tires slip a little on a less grippy surface. Because the traction is so good on a drag strip it doesn’t see any slip and protects the drivetrain. I slipped the clutch a little and left the line at about 3k rpm. My reaction times were garbage though. LOL!!
https://youtu.be/cG6fk5f_-LY
Edit:also no lift shift is your friend!!
eimarshall is offline   Reply With Quote
Old 06-21-2019, 06:57 AM   #9
HouseStark
Originally Posted by biker2k View Post
what was your mph
My 13.42 was @104mph. I was spinning moderately badly wasn’t very bad but I also wasn’t getting the jump I wanted. I agree it was weird competitive felt less intrusive then track/race which I though race was suppose to have all nannies off.
Old 06-21-2019, 07:04 AM   #10
HouseStark
Yeah I agree it’ll get better. Haha I don’t know if I’ll get close to you but it was my first time ever racing it. I only have 850 miles on the car so I’m still getting used it. Very different from my Challenger.
Old 06-21-2019, 07:06 AM   #11
HouseStark
Hope this helps.
Damn that’s great times. So you launch at 5k? Do you have drag radials or the stock Eagles?
Old 06-21-2019, 07:07 AM   #12
HouseStark
My mph I believe was 104. The cut off I have no idea what was happening it was in track race mode in first only.
Old 06-21-2019, 07:19 AM   #13
HouseStark
I’m sure there’s a Silverado forum somewhere where this would be relevant.
Old 06-21-2019, 08:13 AM   #14
DFW1LE
DFW1LE's Avatar
If the car is spinning like crazy it will effect both ET and MPH. Looking at finish line MPH is more meaningful once you start launching the car and shifting better.
Make no mistake, launching an M6 SS1LE well takes a lot of practice and proper setup. Comparing a8 times to your car is meaningless.
Frankenstein Engineering Dynamics Stage 1 H/C/E85 536HP/488TQ
