Old 04-29-2018, 10:08 AM   #85
KLG
KLG's Avatar
Drives: 2016 2SS Convertible
Originally Posted by Pollock View Post
Dont tell them and they will never know.
Probably true, unless you use Royal Purple!
2016 2SS Convertible; SIM; Black & Ceramic White interior; M6; NPP; DD LED side marker lamps & back-up lamps; LED trunk lamps, license plate lamps & front T/S lamps; 3rd brake light pulser; Skip-shift eliminator; Borla s-type non-npp axle backs; Weather-Tech floor mats, trunk mat, rear license plate frame/cover; GM fuel door; ZL1addons rock guards; Removed fender badges, front & rear SS badges; JLT CAI, tune, oil separator; RP Synchromax in transmission; RP MaxGear in rear differential; GM Lowering Suspension Upgrade; Dimple oil filter magnets & magnetic oil drain plug; 3M Ceramic window tint.
KLG is offline   Reply With Quote
Old 05-28-2018, 06:35 PM   #86
6spdhyperblue
Drives: 6th gen
Changed my trans fluid today. I’ll be taking it on a work trip Wednesday 150milles so I’ll see how it feels then.
But was under the car and saw this...see something missing?
Overall a good day to work on the car
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold)
Old 05-28-2018, 07:02 PM   #87
waterman
waterman's Avatar
Drives: Grandad's C2 L89
Looks like the nut that secures your right side primary cat.
2018 ZL1 1LE sw/PDR
Old 05-29-2018, 02:26 PM   #88
6spdhyperblue
Drives: 6th gen
Yeah. can anyone help me find the part number for that nut?
Edit:Still no luck...wonder how much false knock that sumbitch was responsible for. Might have to use a sears hardware grade 8 for the time being
Old 06-06-2018, 12:22 PM   #89
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
It's PN 11546441. M8 x 1.25 thread if a dealer or online can't get you one fast enough.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 06-07-2018, 09:10 AM   #90
6spdhyperblue
Drives: 6th gen
Thank you sir. Just ordered it. Much appreciated
Old 06-15-2018, 07:35 AM   #91
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
Did this for the first time last night. Had 22k miles on my original fluid. Changed it with the car on ramps and squeezed my floor jack under the trans to support it while I pulled the 6 15MM bolts on the trans mount. Be advised a 3" extension is too long to get to the fill plug! It was 10:30 last night and I had to make do with the tools I had so I used some pliers to get to the fill plug.
Results:
Shifting is NOTICEABLY SMOOTHER. I can't wait to see how much better it feels on track. I occasionally would have a missed 1-2 shift even when I felt I was pulling it all the way down into second. Also the 4-5 shift was pretty notchy on track in the past.
Old 06-22-2018, 02:43 PM   #92
Whitespeed
Drives: 2018 1SS 1LE & 1973 Datsun 240Z
What's the thread size on the drain plug? If there's a thread size that matches, is there room to replace it with a Fumoto valved drain plug with hose attachment?
Nigel
Whitespeed is offline   Reply With Quote
Old 06-24-2018, 01:25 PM   #93
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: 2016 red hot 2ss M6
I changed mine following the service manual. Used the sensor plug as the drain plug,and masked off the surrounding areas with plastic. No need to remove the trans mount lol. Simple, clean, drain and fill. took ~3.5 qts Amsoil ATF once I removed the excess, shifts much smoother now.
Attached the service manual flush procedure. Again, no need to remove any bracing. Its not messy if you follow the manual and mask off the surrounding areas. I just used 3 zip lock bags and some duct tape.
soloknight6 is offline   Reply With Quote
Old 06-24-2018, 01:56 PM   #94
waterman
waterman's Avatar
Good info. Thanks for posting.
2018 ZL1 1LE sw/PDR
Old 06-24-2018, 02:56 PM   #95
soloknight6
SoCal HT5! SD
no problem!
Old 07-05-2018, 03:47 PM   #96
Texan4iu
BLEW BIU
Texan4iu's Avatar
Drives: 2018 2SS 1LE Hyper Blue
Changed my Trans fluid to RP Synchromax this past weekend. Just wanted to give a huge thank you to all of you for your great info on this thread, especially the OP. Shifts like butter now!
Texan4iu is offline   Reply With Quote
Old 07-10-2018, 02:16 AM   #97
protovack
Drives: 2019 2LT 2.0T M6 Riverside Blue
can someone go into more detail about how you get the fluid level correct? The service manual says you can fill to the level of the fill hole, then remove 8 oz of fluid. How do you remove exactly 8 oz of fluid from inside the transmission?
Or, using the other method, how do you make sure the level is 3.2mm below the level of the fill hole?
protovack is offline   Reply With Quote
Old 07-10-2018, 02:22 AM   #98
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
get a syringe that measures oz or something that measures 8oz and suck out 8oz. they have 2 stroke oil syringes at walmart
you can also take a wire like a hanger and bend a L into it and mark 1/8" from the bend.
