06-25-2019, 01:50 PM | #15 |
Coopers Camaro
Drives: 18 Flex Fuel LTG Join Date: Nov 2016
Don't get caught up in the chatter Wook. Your graph is right, and almost matches your dyno identically. I only suggesting adding a variable to your HP math to bring that number closer. 295x.09(-30) = 265 Much closer to your dyno.
06-25-2019, 08:21 PM | #16 |
Drives: 18 Camaro LS M6 Join Date: Apr 2019
ok then. We have a couple of ideas and conversations going on, I just wanted to try and accomplish allot, sometimes a thing takes on a new path, as usual.
I am gonna give this ONE more try then let it rest. In the final analysis all I am trying to accomplish is the Knock Retard. I am pretty happy with the power numbers, yes and along this narrative I will try to be as clear as possible. Not with attitude or anything like that, just emphasis on what I am trying. I did a RC chip and a Borla Midpipe and then went to the dyno guy. I got this chart that started the Thread. So far so good. The numbers surprisingly matched up well with RCs "as advertised" numbers, even though I threw it a curve with the midpipe. I was surprised. I knew the spool was slower. Its just an expected result and that's what I experienced. Fine no problem there. Next I installed the JacFab Valve and NGK 6510's. By now I was interested in actually getting my own charts as a reference, at the very least I could calibrate the delta, and save on interim visits to the dyno guy. Great! By the time I figured out how to get a good capture on a section of road I can always go back to I had, my 4 mods as described, and I figured out how to get these graphs. First thing I wanted to know was - WELL? What is the difference Actually? How much should I adjust to get a 'feel' for what I would get at the dyno guy.... As do all of us I am assuming. Well, I put the information here. There is no smoke and mirrors, nor corrective factors or cheats or any silliness. As a side note I have an advanced education in math and statistic analytics. Believe me. I know how to make numbers tell the story I want if I wanted to. But none of that here. Just the facts Ma'am. FIRST - the HEAD TO HEAD Dyno Vs HP with on-board sensors (generic pid) if I recall. THERE IS A CAVEAT HERE - I ADDED the JAC VALVE AND NKG 6510 SINCE THE ORIGINAL CHART, SO I EXPECTED A SLIGHT POSITIVE GAIN. There is a slightly positive gain in the HP SCANNER Graph. YUP another curve ball..... SO THIS- Represents the Head to Head Dyno vs Internal Sensor Power Chart. *with a known new variable, the jacfab and the nkg 6510 @ .0275 plugs. Which were put in, after the original chart. The results are here: THere is a reasonably Strong equal correlation bewteen Dyno and Sensors IHMO. I have the static pic AND a moving picture - ONE THING TO NOTE- is the Knock Retard. I also got enough PING at the dyno test, that the tech pointed it out. HERE IS the Static Image of the comparison test run. HERE IS the above image in playback mode. IT has the KR and the boost and the other good metrics in motion. https://youtu.be/w4IBClB62rs GREAT! That is the first point. THE SECOND POINT Is taking my new TOOL and getting a reasonably reliable Graph with the Newly Added ZZP Downpipe. Same thing, no tricks no smoke and mirrors or partial or cropped readings. Here is my Current Chart that shows my area of most interest seems to be a reduction in KR! Its a positive direction. Also what seems to be implied is the stock turbo is pumping its little heart out and its fully maxed in its function. I am not exactly sure why I think that, but I do. ANyways here is the current setup as it sits in my driveway. RC RS 5/6, NKG 6510 @.0275, Borla resonator, ZZP Catted DP, JacFab. 295HP/315tq, +33/+4 zzp catted DP effect combined with the other mods. Static pic- Video - https://youtu.be/qrgWg2DIqPY KR fixes ideas, meth injection / cutout exhaust / reduce the tune (: Happy motoring! WW. Last edited by wookwook; 06-25-2019 at 08:35 PM. |
06-26-2019, 08:59 AM | #17 |
Drives: 2019 Chevrolet Camaro 1LT 2.0T Join Date: Mar 2019
Wook, holy shit. Thank you for taking the time to do all of this. I am absolutely loving it.
Looks like the ZZP Catted DP was a worthwhile adventure. What is your take on the "feel" of the car with the DP added? How do the changes in the low-end, midrange, and high-end feel to you..."seat of the pants" type thing? |
06-26-2019, 11:02 AM | #18 |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
Excellent post! Thanks for sharing!
06-26-2019, 03:20 PM | #19 |
Hah lol. Thanks I wasn't expecting that! I am glad u guys found it informative. I think next time I can get another test I will put the RS on 4. And see the result. I am just trying to figure it all out.
06-26-2019, 03:24 PM | #20 |
Oh yeah, your question. Zzp chatted DP is the shit. Totally woke the car up. Almost like the same jump to tune vs stock.Perfect "in the pocket" type of drivability. You will really appreciate with the xlr. And then ur tune of choice will work fine and multiply the benefit of the breathing room.
06-27-2019, 08:14 AM | #21 | |
06-27-2019, 08:45 AM | #22 |
Good. Also I just wanted to make a mention that we have the benefit of the guys who paved the way before so really it's kudos to those who found and published all their info. I just took the opportunity to dig in a little deeper and hopefully supported all the work others have done here. They have spent countless hours testing and tuning and reporting. So it's a crowd effort. Sometimes stuff didn't turn up as expected and others where surprises that worked well. We are all into getting our car to the personal settings, by trial and error. But that is what makes this so fun! The thanks to all.
06-27-2019, 08:59 AM | #23 | |
Once I get my RC back and confirm that it works, I'll get on a dyno and post my information. These cars are so incredible for the modifications that can be done to personalize it. |
06-29-2019, 07:41 AM | #24 |
Updated table of power results.
06-29-2019, 07:53 AM | #25 |
Awesome stuff, Wook. Can’t wait for my downpipe to be in. At that point we will have very similar setups and I’ll find a dyno to run as well. 295 hp and 315 tq at the wheel is nothing to take lightly! While the addition of the DP only rose tour max tq by 4 ft-lb, the jump at 2000-2500 rpm really sticks out to me. I’m pumped.
06-30-2019, 08:13 AM | #26 |
yeah. so wrapping my brain around the torque and hp. So torque is measured and HP is calculated using RPM with a variable factor of 5252. That is how they are linked. The how one reads the chart is "how much work is it taking (HP) to make the force applied (TQ) to the contact patch on the tire", using 1-1 which 4th gear on M6 is 1-1 with the obvious inherent errors, like factory calibration for tire size, air pressure diameter, slippage, etc. but its close enough for our purposes. You can get much higher TQ readings using more leverage with lower gears, but usually in reporting stuff, its assumed your talking 1-1.
Also you may not get the right result if you are trying this on a level surface. You have to use a good incline so all the work of the engine is required and can be measured. That's why on my dyno run, I could smell some rubber burning off the rollers. I found a spot that is about 3000 ft of steady incline with an on ramp so I can start from a slow speed in 4th, and get the full pull to about 5k before it gets dicey. |
06-30-2019, 11:09 AM | #27 | |
603 Camaros
Drives: 2017 NGM I4 1LT Coupe Join Date: May 2012
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile |
07-02-2019, 08:19 AM | #28 |
Ordered last Thursday and still no confirmation of shipping
