Old 05-29-2020, 03:10 PM   #29
900RFWN
900RFWN's Avatar
Drives: ‘18 ZL1 1LE
Is it the stealthbox with the W6? What amp do you have on it?
900RFWN is offline   Reply With Quote
Old 05-29-2020, 03:15 PM   #30
puppykat33
puppykat33's Avatar
Drives: Black 2019 ZL1 M6,
yes its the W6 and the amp i have is the one JL recommend to go with the stealth box XD600/1v2
2019 Black ZL1, M6, CF Hood and Dash, Nav System, ZL1 Addons rock guards and lift points, Michelin Pilot Sport 4S, DD Smoked Marker Lights, Ceramic window tint, Gtechniq 9yr ceramic coating. JL Audio stealth box 12W6, Dyanamat trunk, Dead pedal cover, Soler TB/TC, Green Filter, Carbon-fiber Borla S-Type
puppykat33 is offline   Reply With Quote
Old 05-29-2020, 03:17 PM   #31
puppykat33
puppykat33's Avatar
that amp will fit in the flat tire foam thing under the floor with alittle trimming with a serrated knife if you dont want to fabricate a whole amp rack . i also put a lc2i on it
Old 05-29-2020, 03:20 PM   #32
900RFWN
900RFWN's Avatar
Drives: ‘18 ZL1 1LE
The battery in the trunk is icing on the cake. Easy peasy. Thanks for the info.
Old 05-29-2020, 03:24 PM   #33
puppykat33
puppykat33's Avatar
no prob i also used the ST wiring harness so no wires were cut. all in all it can go back to factory verry quick and easy. i did buy another left side trunk liner since you half to cut a hole in it for the stealth box. i wanted to be able to return the car to factory if need be
Old 05-29-2020, 03:37 PM   #34
900RFWN
900RFWN's Avatar
Drives: ‘18 ZL1 1LE
I don’t plan on cutting anything up either. I knew that Bose was a PIA but learned yesterday that it’s more than I thought initially. I was eyeing this site for T harnesses and LOC/DSPs.
https://lljcustoms.com/store/ols/pro...-amp-t-harness
I’ll end up having to use a better module to interface though. Might as well do it right the first time.
Old 05-29-2020, 03:45 PM   #35
puppykat33
puppykat33's Avatar
The S T harness is blank with the speaker leads out for you to use so you can add whatever line out converter you want to it
Old 05-29-2020, 06:37 PM   #36
900RFWN
900RFWN's Avatar
Drives: ‘18 ZL1 1LE
I was thinking about using the T harness initially but from my understanding the Bose system will still send an uneven signal and cause audio anomalies. Including different equalization based on volume level and will introduce sub frequency roll off despite the harness and LOC.
Old 05-29-2020, 07:09 PM   #37
2004YZFR1
Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE
I didn’t know about this company. I bought the harness from subhump and it’s more expensive and they charged about $17 to ship it. Which is excessive.
2004YZFR1 is offline   Reply With Quote
Old 05-30-2020, 07:19 AM   #38
puppykat33
puppykat33's Avatar
thats the one im talking about Sub Thump = S T...
the whole bose system will max volume around 55% of the level so the bass roll off is handled by the lc2i. if you are amping all of your speakers i would reccomend daisy chaining the amps but getting the amped signal back to all speakers is going to be a monumental task. I am picky but with just the stealth box and correctly tuning the amp and lc2i the system really does sound great
Old 05-30-2020, 07:22 AM   #39
puppykat33
puppykat33's Avatar
well if you use the lc2i there is a high and low output on it so you can run your sub amp and your other of the high output. the accubass fixes the roll off
Old 05-30-2020, 11:54 AM   #40
RLNTLSS
INTSAGRAM: Failwish
RLNTLSS's Avatar
Drives: 2019 /2SS LT1
The t harness just taps in the signal wire of the bose amp and gives u the proper (+. - )output. Bose figured miss matching wires would keep people from fooln with ther systems..and the t harness correctly fixs the connection to the amp from the bose..Wiring capability..the lc2i..is the butter of all this u can keep the boom constant with no roll off.. and have proper connects to amp and get the signal needed for clean install and soundstage
2019/LT1 2SS
RLNTLSS is offline   Reply With Quote
Old 05-30-2020, 12:10 PM   #41
900RFWN
900RFWN's Avatar
Drives: ‘18 ZL1 1LE
Do you folks with the LC2i have your sub amp plugged in to the ‘main’ RCAs? I’ve heard a lot of people complain about the accubass not being accurate and randomly adding way too much bass without even touching the ACR-1.
Old 05-30-2020, 12:27 PM   #42
2004YZFR1
This is the company that I didn’t know made adapter harness set ups. I would have gone with them instead.
