01-11-2013, 02:36 AM | #1 |
Drives: 2005 rsx, 2012 camaro 2lt t3 ed Join Date: Feb 2012
nor cal store/shop that will put on my gfx
Hi guys I need your help I'm looking for a shop that will install my gfx for my 2012 t3 camaro Is there any shop that you will recommend near citrus height-sacramento area. Thanks!
01-11-2013, 09:03 AM | #2 | ||
Drives: 2017 1SS 1LE - Hyper Blue, P85DL Join Date: Jul 2011
If you have the time and a few good beers it's not the worst thing to do yourself.
I just did it using these videos. On the side skirt one I didn't use the hammering method either since I was lowered I didn't have a good angle. I just went to town on the clips and didn't have a problem. I'd say 1 hr for splitter (if like ACS) 2 hours for side skirts since you should take your time 1 hour for diffuser (getting the rear bumper off is one of the easiest things to remove on the Camaro) |
01-11-2013, 05:24 PM | #3 |
thanks for the reply. I'm planning to do the side skirt then have the shop do the front splitter and rear
01-11-2013, 05:24 PM | #4 |
You guys have any idea on how long it will take to install a razzi ground effects?
01-12-2013, 12:43 AM | #5 |
the rear is really not that hard to put on. it looks worse then it is, but i have not done the front piece. I was guess 3 or so hours for sides, front and rear.
01-14-2013, 11:16 PM | #6 |
thank you cyber ls!
01-15-2013, 11:51 AM | #7 |
capitalcitycamaros.com
Drives: 2010 Cyber Grey 1SS Camaro 6sp Join Date: Nov 2009
MSI in old Roseville would help you out and I know they have installed the Razzi kit before.
01-15-2013, 02:13 PM | #8 |
need....more....hp
Drives: The Neighbor Hater Join Date: Dec 2010
if you want a shop to install them for you, check out Blu808 in Campbell, they have installed various body parts for our Camaros.
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims |
01-16-2013, 02:41 PM | #9 |
Thanks guys. You do you remember how much it had cost you?
01-16-2013, 11:34 PM | #10 |
I'm guessing it would be $160-$240 at Blu808 (don't quote me, I don't work there). Assuming 2-3 hours.
01-17-2013, 12:26 AM | #11 |
Drives: Z28 Join Date: Jan 2013
There's a shop on fulton and fair oaks across from loehmann's plaza I drive by all the time that does aftermarket work for some really highend cars.
I can't remember the name right now, will post the name the next time I drive by. If I was on faster internet I'd google map it! |
01-17-2013, 01:38 AM | #12 |
@falundir but that's too far I'm in sacramento I wish i was there.
Onslick can you please post it asap? because I was planning to go to force fed performance but they dont have a good review online. Thanks! |
01-17-2013, 01:48 AM | #13 |
Have you tried shopping around at dealerships?
01-17-2013, 01:54 AM | #14 |
I havent tried but i think they charge 125 per hour. At force fed performance 85 but i dont know if they are experienced with it.
