Old 01-10-2020, 12:27 PM   #1
Lt1ftw
Drives: 2016 Chevrolet Camaro SS
Diy 15” conversion
I just finished my 15” conversion that I pieced together myself. I used a set of v6 rotors combined with 2016 ATS calipers. The calipers will require some grinding for clearance with the amount of grinding depending on wheel choice. Aftermarket toe arms will be required as well. Along with this you will need banjo bolts to fit the calipers to the factory lines. BMR toe arms, modified Cadillac ATS calipers, v6 rotors 12.4” diameter, jegs ssr vision 15x8” wheels, and hoosier 15x27x10.5 qtp’s.
Lt1ftw is offline   Reply With Quote
Old 03-05-2020, 07:29 PM   #2
Sixgunsled
Sixgunsled's Avatar
Drives: 2017 camaro SS 1LE
how much was it for parts not counting the wheels and tires?
2017 1000+hp Camaro SS
88/96 single turbo
manual to TH400 swap
15" conversion
Port injection
22K+ followers on Instagram @Sixgunsled
6.4K subscribers YouTube: Sixgunsled
Sixgunsled is offline   Reply With Quote
Old 03-08-2020, 10:42 AM   #3
ramairroughneck
Drives: 2018 Camaro SS
Got any pics of the calipers after the grinding?
ramairroughneck is offline   Reply With Quote
Old 03-23-2020, 09:04 AM   #4
DorkMissile
DorkMissile's Avatar
Drives: 18 1SS 1LE HyperBlue
Well just for informations sake - those calipers are the ones used in the GM kit, but they spec a 16" wheel. With the 16" wheels you can use the stock toe rods (the route I am probably going to go with)
LT1FTW - what actual version of the calipers did you use? Or the PN#?
2018 1SS 1LE / HBM - ECS Novi 1500 S/C Tuned by Carl @ CJ Tunes
DorkMissile is offline   Reply With Quote
Old 04-01-2020, 12:50 PM   #5
Lt1ftw
I used ACDelco GM OE Disc Brake Calipers 13584520 ordered from Summit.
Old 04-06-2020, 08:25 PM   #6
ramairroughneck
Does that part number include both the left and right calipers? Also, do you use the ats Banjo bolt?
Old 05-19-2020, 11:41 PM   #7
Lt1ftw
Yes you will need the ats banjo bolt. I used the same pn on both sides. You just have to bleed the the side with bottom positioned bleed screw using a hose connected pointed up 8-10 inches above the screw.
Old 06-11-2020, 11:05 AM   #8
Lt1ftw
If anyone is interested in taking on this conversion check out Slowvert youtube channel. He has made a how to video on this.
Old 05-14-2021, 09:10 AM   #9
onig
Drives: 2018 ZL1 1LE
Lt1ftw,
Can you share a part number for the Jegs wheels pls,
Need the correct back space
Thank you
onig is offline   Reply With Quote
Old 05-21-2021, 06:26 PM   #10
StPeteHyper2.0
StPeteHyper2.0's Avatar
Drives: '16 Hyper Blue 2.0
Nice job. I did mine last year on a LT.
StPeteHyper2.0 is offline   Reply With Quote
Old 05-23-2021, 08:39 PM   #11
BDPhoto519
BDPhoto519's Avatar
What 15" racestar wheel is that? Part #?
2018 Camaro 2SS A8 Redline Edition
BDPhoto519 is offline   Reply With Quote
Old 06-02-2021, 08:31 AM   #12
SLOW.VERT
SLOW.VERT's Avatar
Drives: 2016 CAMARO SS
I used 510254DP
15X10 7.25 BACKSPACING
1st N/A 10s vert 10.85@125 Slow.vert youtube: https://www.youtube.com/channel/UC26..._as=subscriber
SLOW.VERT is offline   Reply With Quote
Old 06-04-2021, 04:16 PM   #13
StPeteHyper2.0
Originally Posted by SLOW.VERT View Post
I used 510254DP
Yes.. this Part number.
Thanks for youtube video slow.vert
Old 06-10-2021, 01:22 PM   #14
SLOW.VERT
SLOW.VERT's Avatar
thanks for watching!
