Old 11-23-2019, 01:06 PM   #1
OVRKLL
Drives: 2017 1SS 1LE...makes me go YeeeHaw!
Header Bolts Anti-seize
Sorry if this question is one of those that has a given answer, but I've never did this before.
When installing Kooks Headers or headers in general, do you use Anti-seize on the bolts, or install it dry?
I have SS bolts from Summit, and Permatex Anti-seize with a 1,600 degrees F.
Or is there a special Anti-seize for headers to withstand higher temps?
Also, what about on the O2 Sensors?
Thank you!
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late!
OVRKLL is offline   Reply With Quote
Old 11-23-2019, 01:47 PM   #2
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
Pretty sure nothing is going to withstand header temps.
Plus unless you plan on swapping out the part frequently, why would you want anti seize?
