02-20-2019, 11:11 AM | #99 |
Drives: 2019 Chevrolet Camaro SS 1LE Join Date: Nov 2016
I would eliminate the openings above the exhaust outlets---it's too reminiscent of the C5 Corvette. I also think the front end is too tame and needs to be more aggressive.
02-20-2019, 08:09 PM | #100 | |
Dances With Mustangs
I can make the line across that opening above the exhaust black which makes it look slightly less busy, but if I remove the opening completely, that leaves an awful lot of empty space from the middle of the bumper down. Here's a couple of shots with the line, and with it blacked out: When you say the front "needs to be more aggressive", what do you mean exactly? Have anything specific in mind? I think the front looks pretty classy as-is: What would you like to see changed?
Blue Angel is here!! 1SS/RS LS3 M6 IBM |
02-20-2019, 09:04 PM | #101 | |
Concerning the front-end styling of the vehicle, I'm not quite certain what it needs. Perhaps it could benefit from being lower and wider with a larger lower grille opening. The visual mass of the front end is too "light" (i.e., narrow and tall) compared to the rear end, which is visually "heavy" (i.e., wide and muscular---a good thing). Regardless of my opinion, your renderings continue to improve with each revision, so keep up the great work! |
02-20-2019, 09:58 PM | #102 | |
Now to do something about the hood. I'm also entertaining the possibility of a heat extraction vent on the side behind the front tire. I think that would visually help give it more 'aggression'.
02-20-2019, 10:11 PM | #103 |
Looks great, Doc! Perhaps you could add some sculpting to the top of the front fascia, hood, and roof to make it a bit more aggressive.
02-21-2019, 01:48 PM | #104 | |
As for the hood... Here's the latest. On the front I did the following: Removed the vertical piece of DRL in the brake duct so it would be more of a brake cooling duct. Put fog lights in the outer corners of the lower grille opening. Hood has a cooling/intake piece on top. This was a style I vaguely remember from way back when, like back in the 60's or 70's. Not sure what it was on, but it was something like this which I think works for this style hood. Put heat extractor vents on the sides of the car behind the front wheels. And just for fun... I don't usually use dark colors like this (especially black) because the light room set I'm using doesn't provide the kind of environment where a dark color lets you see much. In an outside environment the darker colors will work well on this car.
02-22-2019, 02:58 AM | #105 |
Trying some different things with the front fascia, as well as the headlights and DRLs. Does this look a bit more aggressive?
02-22-2019, 02:44 PM | #106 |
At the request of a forum member, I flattened the roof a bit. I also stretched out the DRLs in the front so the angle would match the angle of the ends of the upper grille intake. I've also done small bits and pieces of detail work that I fix/adjust as I come across them.
I did some detail work on the rear diffuser area, as well as making the rear window more realistic as far as size and shape. When I get the interior done, window openings all around will reduce due to interior pieces being in place. I'd like to come up with something for a rear spoiler, but I haven't figured out what I want to do yet.
Blue Angel is here!! 1SS/RS LS3 M6 IBM Last edited by Doc; 02-22-2019 at 02:45 PM. Reason: left a word out |
02-22-2019, 03:51 PM | #107 |
could you lower the door handles below the belt line? it would be hard to open the doors in their current location.
It's been fun, done with GM.
2018 Camaro ZL1 (SOLD) - Blown Airbags 2017 Camaro SS F1FTY Member Journal (SOLD) - Bad Motor |
02-22-2019, 05:03 PM | #108 |
Drives: No Camaro...yet Join Date: Jan 2019
I read the forums, hoping to get a Camaro when my daughter graduates college. Your concept is one I would buy.
02-22-2019, 05:40 PM | #109 |
Drives: C8 Corvette Join Date: Mar 2013
I used photoshop to rework the car a bit how I think it could be improved.
Changes: - Changed frontend to a more classic muscle car look with 2nd gen inspired headlights - Tried to make lines one the frontend between upper and lower grille more flowing - Also 2nd gen inspired bulks next to the frontwheels on the bumper - Extended the hood lines to the frontend - Made the side more interesting by adding integrated sideskirt lines Upper one is the original, lower one my version
02-22-2019, 05:58 PM | #110 |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
I keep thinking 'Jaguar XKE' when I see how high up the bottom of the door is. That's a lot to be stepping over, and while I could probably still cope with that well enough I'm even more sure that my 5'-1 wife would refuse to.
Norm
'19 WRX 6M (the family sedan . . . seriously) |
02-22-2019, 09:38 PM | #111 |
I had the same observation prior to reading your post. It definitely needs to be addressed.
02-23-2019, 01:13 AM | #112 | ||||
As for Samurai's version, that's not so easy to do. The tops of the fenders going down to the headlights are quite curved, and cutting back into them won't produce a straight line above the headlight the way he drew it. It would require a complete rework of the entire top of the front half of the car which is way more work than I want to put in for that. Nice idea though. Just so you know what I'm working with, here's a pic of the wire mesh. I hid the wheels and interior. With regards to the lower part of the front, that's more doable. However if I straighten out the lower edge of the upper grille opening like he drew it, that starts to go back to a retro design, almost 5th gen-ish. Which isn't necessarily bad; that's the gen that sold the most, but I've been trying to do somethiing different enough to not be a retro design. I'm making a conscious effort to not go too aggressive. As I stated above, this concept is supposed to be more friendly towards the 98% of the market that are not Camaro owners. If GM could capture just 10% of that group, that would add thousands of car sales a month which would go a long ways towards keeping the Camaro alive and in production. Side skirts and such could always be an aftermarket add-on, but wouldn't be a standard item. Ideally I can come up with something that's in the middle; aggressive and edgy enough to appeal to the enthusiast crowd that they can then modify, but still conservative enough to not put off a parent from buying it as a third family car. No parent wants to buy a car for their kid that they feel looks menacing or dangerous, yet that's exactly the look the enthusiast crowd wants. Finding the middle point between the two is not an easy task. Everyone's observations and constructive feedback are more than welcome however! Some of you are focusing on some very fine details, but that's good!
