02-11-2019, 01:00 PM | #71 | |
Drives: 50th 2SS MRC A8 NPP Join Date: Jan 2017
The tail lights definitely look better (to me) when you pull the lenses together as opposed to the split look from earlier iteration. I feel like the orange is a bit dated, too. Maybe go solid red on both with a thin break between them, like the '67? I'd maybe drop the reverse lights as well, similar to the 67. Maybe a center pod under the license plate in the rear splitter? I can't really visualize it in my head, though. May look terrible.
Club F1FTY
50th 2SS, MRC, NPP, 8A, #991 Join the Club F1FTY Registry! Add yourself to the registry here. Read the registry here. |
02-11-2019, 02:33 PM | #72 | |
Dances With Mustangs
One with a split orange turn signal/back-up light lens. One with the back-up lens being just the orange turn signal, and I can put a back up light somewhere else; probably on either side of the license plate. And one with the back-up lens having a double-duty function; either a back-up light or orange turn signal depending on which row of LED's inside are used. Any of these work for you? Oh and for Norm; these all have wider tires.
Blue Angel is here!! 1SS/RS LS3 M6 IBM |
02-11-2019, 02:36 PM | #73 |
I for sure like the bottom one best!
Club F1FTY
02-11-2019, 04:43 PM | #74 |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
'19 WRX 6M (the family sedan . . . seriously) |
02-11-2019, 05:34 PM | #75 |
Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
Doc, pretty sure rear turn signals cannot be orange. White or orange are ok for front turn signals, rear turn signals must be red.
Also, you need a third/middle rear red brake light. And side markers need to be orange in front and red in the rear, not orange rear side-markers. Last edited by 90503; 02-11-2019 at 06:54 PM. |
02-11-2019, 07:52 PM | #76 | |
Here's a pic of a 2016 Camry which shows a clear lens and an orange bulb inside. I see this arrangement more often than an orange lens. I've had this idea for a long time, so here it is with the 3rd brake light in the back of the shark fin on the roof. I don't know if there's a requirement on size of the light; I see many different sizes on cars from a small rectangle to a much bigger one. This image also has the corrected red outside rear fender running/turn light.
02-12-2019, 03:42 AM | #77 |
Latest images. Finally fixed a problem with the side of the roof on the sides of the car, and added welding seams on the roof. The roof now smoothly curves on the sides like it should.
Here's a shot with the front license plate: and one without the front license plate: Still haven't figured out what I'm going to do with the hood, but for now I think I'll start working on an interior.
02-14-2019, 09:33 PM | #78 |
Well after I started working on the interior, I kept noticing things I wanted to change on the exterior, so I stopped on the interior and started making changes. Wound up reworking the entire side of the car, including some changes in width of the front. By the time I was done, I was surprised at how much it changed the character and personality of the car.
02-15-2019, 07:07 PM | #79 |
Drives: 2017 RS Garnet Red Tintcoat A8 Join Date: Oct 2017
JMO, but the front end is hideous. From the side it reminds me of the shape of a long gone Suburu coupe that a friend had in the '70's.
02-16-2019, 02:45 AM | #80 |
Drives: 2011 Camaro SS Join Date: Apr 2013
What about something like this? It keeps a bigger greenhouse and most of the proportions but brings back some of the 6th gen refresh styling, since that might be a basis for the 7th gen if there is one.
Disclaimer: Unless specific sources are cited, all of the above is my subjective opinion. No warranties, expressed or implied, are granted. This is a car forum, after all.
02-16-2019, 03:22 AM | #81 |
That has some possibilities; especially the front. Nice.
02-16-2019, 03:28 AM | #82 | |
I raised the entire top of the car from the windshield forward about 4 inches. Been working on rounding and smoothing things out. I was already considering getting rid of the retro grill. The only way to get away from retro is to not do retro. I reworked the headlights and worked on trying to balance the proportions better. It still needs work, but it's getting there. I also made some changes to the back. It needed some flair so I pulled the top part of it back to create a sense of a spoiler.
02-16-2019, 07:13 AM | #83 |
The trunk area is definitely getting a "lighter" feel, like the originals had. Nice.
That's a good thing in this day and age where everything looks like it wants to be bulky/thick-bodied. Thick-body may be a fine look for a truck, but car styling should be lighter and more graceful. Norm
02-16-2019, 11:45 AM | #84 |
Keep at it, Doc. I liked the ridge/step/toggle that ran the length of the sides....I was going to suggest that would be a good spot for a trim strip at the furthest out-board line to absorb door dings from other cars....
Also, I like it having the front license plate. Maybe massage up the front plate area as if the car is made to have a front plate, instead of the terrible look of a front plate on the car that looks completely out of place....Just my $.02.. P.S. And in the trivia department, front plates don't need the year and month sticker...lol |
