02-21-2018, 12:20 PM | #1 |
Drives: 2016 Red Hot 2SS Join Date: Feb 2018
S8+ with charging pad.
Has anyone found a way to make the s8+ compatible with the wireless charging pad? I did some research and the threads were all older and multiple people stated they were working on a way to make it happen but never updated the threads.
Just curious if anyone knows. I am picking up a 2017 2SS this weekend and wanted to know what I needed to do to make it work if possible. |
02-22-2018, 10:46 AM | #2 |
Drives: 2016 Camaro RS, 2LT Join Date: Aug 2010
I don't have an answer to your question, but my S8+ won't connect with Pandora (bluetooth) or Android Auto (wired) unless I turn wi-fi off first (even though I'm not even close to a wi-fi source). Let me know if you experience a similar problem with your S8+.
02-22-2018, 11:58 AM | #3 |
Ok, I will let you know.
02-24-2018, 09:12 PM | #4 |
Drives: 2018 Camaro 2SS Join Date: Sep 2017
I pulled the pad off and removed case around phone to make it work. Your better off using usb cable with android auto.
02-24-2018, 10:58 PM | #5 |
Drives: 2017 Camaro 2LT 50th Join Date: Aug 2009
I use my S8+ with my Camaro (Can't get it to wireless charge) but I never had your issue. My phone always has WiFi and Bluetooth on. It connects via Bluetooth instantly and once plugged in loads Android Auto without an issue. I know you said you're not close to a WiFi source, but not even the car's?
2017 50th Anniversary Edition 2LT V6
1100 - 09/26/2016 | 3000 - 09/28/2016 3100 - 10/04/2016 - TPW: 10/17/2016 3300 - 10/06/2016 | 3400 - 10/06/2016 4300 - 10/17/2016 | 5000 - 10/28/2016 |
02-25-2018, 11:13 AM | #6 |
Wifi on my 2016 has been off since 3 mos. after purchase (not worth paying for) in summer of 2016, but it could be confusing my S8+. My new S8+ is unlocked (service is AT&T), but that shouldn't be a factor. My S5 had no such issues. I checked settings on the S5 and duplicated them on the S8+.
I'll keep experimenting, but at least the S8+ works fine if I turn wifi off first. |
02-25-2018, 06:49 PM | #7 |
No issues with compatibility with my S8+ Just can't believe nobody has developed a hack for to get it to charge bigger phones.
02-25-2018, 11:55 PM | #8 |
2017 SS
I have a S8 active, I have no issues with Bluetooth or WiFi in my 17 SS. I did try the wireless charger last night. I took out the rubber cover set my phone down, it did start charging but then I hit my phone and couldn't get it to charge wirelessly after that. i usually dive using AA with waze going and music through there also.
